Hello i was wondering how to get the mouse to click into the different sections of xmbc..for example if i want to go to movies the only way to get it to go is to hit enter on the keyboard then the mouse can click on the movie etc that i want..but if i go back to the main part i always have to hit enter to go into that section...weather, videos, power, etc
TY in advance
Sounds like you are using a skin other than PM3.HD. Some skins just don't support the mouse as well as others. PM3.HD, PM3, Basics 101, Basics Vision, and I think Focus all do a great job with the mouse. I'm sure there's other ones that I'm missing!
Aeon, Horizonz, and Mediastream are all not so good with the mouse.
Cheers,
Jonathan
ahh ok....thats to bad i like the skin i have..i will switch back to one of the others to see if that fixes it thx
