Full Version: [FanArt View] Info Text via .nfo?
Pages: 1 2
Hey everybody,
is it possible to view a info text for a movie with a .nfo file?
For Example:
If you use nfo files it should look the same if you use them proper like this
But I dont see any text!
my data:
movie.avi
movie.nfo
My nfo:
Quote: <movie>
<title>Rush Hour zwischen Tarifa Tanger</title>
<rating>0.000000</rating>
<year>2008</year>
<top250>0</top250>
<votes></votes>
<outline></outline>
<plot>Hier steht der Text nachher</plot>
<tagline></tagline>
<runtime></runtime>
<thumb></thumb>
<mpaa></mpaa>
<playcount>0</playcount>
<id>xx00000004</id>
<genre>FRS</genre>
<credits></credits>
<director></director>
<studio>NDR</studio>
<trailer></trailer>
<artist></artist>
</movie>
By the way, i need this nfo, because there are no information about this videos in the internet. So I must make my own nfo. But I dont see anything in xbmc ... I dont understand this with these nfo files Sad
Can anyone help me?
Have you set content on the source folder and scanned into the library? The info wont show without scanning.
Now I have delete my database and added the video again.
But there is still no info text. I think xbmc won't scan after a nfo file.
FRS-FL Wrote:Hey everybody,
For Example:
Just a question: you have enabled Library Mode right?
*It's strange that you only show one file + parent directory on your screen - one might think that you are in files mode
yes, I have enabled library mode!
There is only one file, because I test it befor I add all the movies.
Fanart should not show in files mode in PM3.HD anyways.
What version (svn build) of XBMC are you using?
I used the new XBMC 8.10 Atlantis for windows.
I'm unfamiliar with the id tag format that you are using. xx??
The workaround that I use for setting up movie nfos for movies that are not in the IMDB is to.
Use billyad2000's XBMC Media Companion to build nfos for movies that are in the IMDB, then take one of those nfo files, and copy it to the movie directory of the movie that is not in the imdb to use as the basis.
Open this copied nfo file and edit the plot, rating, title, etc. but leave the id tag as is.
Before switching to library mode, in files mode, I pull up the context menu of the "Movies" directory and ensure that Set Content is set for IMDB (since the id tag format that I am using begins with tt)
You will want to makesure that you have a folder.jpg & or movie.tbn file in the folder so that your movie gets a thumbnail attached to it before you scan for new content.
I dont know, if i add a movie into the database, xbmc shows me the movie id "xx000001".
And so i added it into the nfo data.
but i dont have a folder.jpg or a moviename.tbn ... is that important? what is a .tbn? and how can i build that data? do i need the .tbn for the info text?
I can only suggest the following:
a. use only xml tags you want to show (ie skip all the empty ones and those you have no need for like id).
b. try a newer build.
http://ocs.nl/xbmc/
so, I test it with a newer build version, but it dont work!
I dont understand this, I think it wont work with my xbmc. What a pity!
did you try a?
Pages: 1 2
