Full Version: [RELEASE] Hulu (Video) Plugin for XBMC
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
rwparris2 Wrote:highlight the plugin>context menu>plugin settings.
I am sorry if I was not clear I am using an Xbox (And I new at this) I am not sure how to bring up the context menu using an Xbox controller.
rwparris2 Wrote:read a few pages back (i know it's along thread, but I do mean just a few pages) and you'll realize you don't want to enter a username & password.
I can play the files the plug-in works great. I find the navigation difficult to use when you have 100's of choices. Its easier to create a Queue with a computer and use my online account, then just select from my Queue from the Hulu menu. I could not find the post that would inform me on why I would not use my username and password.
I did have one other question. The "SVN Repo Installer" I am not clear what this is for. From what I read it looks like it is to list available plugging then install them (automatically?) I found this on my system in the "Program" section but when I click it, it does not do anything. From past posts it looks like this is how you would want us to update the Hulu plug-in.
Thank you;
Ray
Small update to remove broken stuff until I have time to do it correctly.
added: warn user & exit script geoCheck fails
removed: search option (until it is fully implemented)
removed: option to log in (until it is fully implemented)
FullMetalMonkey Wrote:Well i got the Hulu website working and streaming videos but when i enter my Username and Password into the Plugin it stops it from opening to the submenus. But without it you can view the items but not watch them so its a catch 22.
Is this true for everyone (i.e. username & password for hulu que just doesn't work) or is it because FullMetalMonkey was trying to do it from behind a proxy (i.e. not in the USA?)
Does it work for anyone inside the USA?
The Joker
rwparris2 Wrote:http://www.hulu.com/about
That's a relief.
It might be nice to append the output of 'svn log' to the readme file, but then again I have a hard time believing anyone would read it Smile
sion28 Wrote:Is this true for everyone (i.e. username & password for hulu que just doesn't work) or is it because FullMetalMonkey was trying to do it from behind a proxy (i.e. not in the USA?)
It works for me, and I live in the US. And I'll be working on the queue feed this weekend. the only drawback is it lists only the first 50 shows I think.
Great plugin. I do have a question about fast forward... if for some reason the video stops and I can't fast forward without the video basically freezing, is there anyway to fast forward to forward say 5 minutes at a time?
hrcolb0 Wrote:It works for me, and I live in the US. And I'll be working on the queue feed this weekend. the only drawback is it lists only the first 50 shows I think.
are you checking it on Windows or Xbox?
both
Mako Wrote:Great plugin. I do have a question about fast forward... if for some reason the video stops and I can't fast forward without the video basically freezing, is there anyway to fast forward to forward say 5 minutes at a time?
no.
Hi everyone,
I'm running crichton's Hulu plugin on the latest t3ch build (2009-01-25 SVN rev17349) on an XBOX. The plugin is working pretty well for the most part, but I've run into a couple of problems:
  1. H264 videos do not play at all. I've seen some other posts where people mention that the H264 videos play too fast or out of sync, but I can't get them to play, period.
  2. Occasionally, the plugin will download the entries for a directory, and then do nothing (i.e. not display any of the entries it just downloaded).
As a followup to problem #2, I see these types of messages in the logfile:
23:50:28 M: 28635136  NOTICE: urllib2
23:50:28 M: 28635136  NOTICE: .
23:50:28 M: 28635136  NOTICE: URLError
23:50:28 M: 28635136  NOTICE: :
23:50:28 M: 28635136  NOTICE: <urlopen error (10055, 'No buffer space available')>
23:50:28 M: 28635136   ERROR: Scriptresult: Error
I've seen some posts about this problem, and people have said "Edit settings.xml", but I don't see a settings.xml and neither does the plugin:
23:36:48 M: 39325696   DEBUG: DIRECTORY::CPluginDirectory::GetDirectory - URL for plugin settings: Hulu/
23:36:48 M: 39325696   ERROR: Unable to load: Q:\plugins\video\Hulu\resources\settings.xml, Line 0
                             Failed to open file
Here is the full logfile showing both problems: http://dpaste.com/118070/
Does anyone have any advice on fixing either problem? Thanks!
does this also work with XBMC linux or just the original xbox? Right now i do not have a source of "video plugins" in my current svn of xbmc linux. If it was added, does anyone know what revision i would need to upgrade too?
Try rwparris2 version ... It works on xbox, linux, windows .
to see your video plugins turn off library function
Video plugins show in library mode. No need to turn it off.
