Full Version: [NEW SOFTWARE] FanArt Fetcher
Ok guys seeming that XBMC now supports MyMovies for all your movie information (which is great by the way) the only real down fall is that MyMovies doesnt support FanArt (Which makes XBMC all pretty and most of us have). Now i have the option to goto http://www.themoviedb.org which most of the built in scrapers use to get FanArt and download them all rename them and put them in the correct folders, but when u have over 1000 dvds this can be a time consuming process. So my propsal is if there is a developer out there that can make a program that allows you to search for FanArt then automaticly downloads the picture and renames it into the movie folder, thus allowing FanArt support.
What are your thoughts and are there any developers out there that would be willing to take this projet on board?
any interest on this or am i the only one.
post deleted
Check out Movie Info PLUS...does just that. There's also XBMC media companion...
