I'm trying to map the recently added movies to my harmony 550 remote in conjunction with event ghost. Is there a way I can do this?
Yep. Use ActivateWindow(VideoLibrary,RecentlyAddedMovies) to get there in keymap.xml. I believe these are listed in the online manual somewhere.
Cheers,
Jonathan
I didn't realise all this info was on the wiki.
I've been trying to display the folder.jpg (which is actually a smaller sized fanart image) contained in each separate movie folder instead of the moviename.tbn and this might be the solution -
Skin.String(name)
Returns the image or image folder set by the user via a Skin.SetPath(name) or Skin.SetImage(name) built in function. Allows skinners to have user-customisable images and multiimages.
All I need to know is how and where to use Skin.SetImage(name).
Looking at it further seems not.
All I want is a command to display folder.jpg.
