2008-12-29, 14:21
2008-12-29, 17:55
from the svn; http://sourceforge.net/projects/xboxmediacenter
2008-12-29, 21:14
Thanks spiff, i've been searching into http://xboxmediacenter.svn.sourceforge.n...eam/Media/ but i can't find the full background for each section, only the splitted backgrounds... There is any way to get the full background pictures (one file for each background)??
regards,
regards,
2008-12-29, 21:49
No.....unless Team Razorfish tells you where they got them before they split the images up.
2008-12-29, 23:18
Ok, let's hope that they tell me where to download them... i want to use it with a skin in MediaPortal (a MediaStream clone)
regards,
regards,
2008-12-30, 14:58
It should be very simple to re-create the background images by combining the relevant 3 images. For example to get the movies background you just need to combine HomeBGMoviesLeft.png, HomeBGMoviesMid.png and HomeBGMoviesRight.png.
There's no need for us to keep the original full 1280x720 images as we can re-create them from the image files we already have.
2009-01-02, 01:17
I have a lott of custom backgrounds incl. Mediastream default backgrounds.
Also extended the weather-fanart pack.
All together almost 7000 backgrounds 1280 x 720.
I can upload these as a torrent file.
Don't now if I may do that.
2009-01-02, 03:27
Thanks Waffa but i'm only interested in the default ones, can u upload them to MediaFire, Torrent or Rapidshare??
regards,
regards,
2009-01-02, 14:30
You don't know what you're missing.
It's just combining 3 images.
But here you go.
http://www.megaupload.com/?d=0D8D7U59
But here you go.
2009-01-09, 19:47
Hey, Waffa.
I'd be interested in those backgrounds!
I looked all over the net for suitable backgrounds, and found that it was harder than I thought....
Lookin' forward to see what you found!
2009-01-09, 23:16
Here you go made torrent file of background folder.
Backgrounds 1280 x 720
Have them also in biggers resolutions.
2009-01-15, 01:34
Wow, I completely forgot about my request until now. Is the torrent still up?
Thanks, btw.
Edit: its torrenting now. Thx!
Thanks, btw.
2009-01-15, 17:46
Torrent is still up. Did also upload same backgrounds but then HD.
http://forum.xbmc.org/showpost.php?p=267...stcount=20
2009-01-16, 04:16
Got em! Seeding now...
There's some really great images in there, thx.
