Musta78,
Are you running audio through HDMI or through the optical port? I had to update Alsa to 1.0.20 to get it working with 9.04.1.
rossgemuend
I'm running through the optical. I've tried to update but I don't understand why it isn't working. I've basicly done what this thread say about updating alsamixer.
This is what I have done and no success:
TEP26
#sudo /mnt/install/AlsaUpgrade-1.0.x-rev-1.17.sh -d
STEP27
#sudo /mnt/install/AlsaUpgrade-1.0.x-rev-1.17.sh -snap
STEP28
#sudo /mnt/install/AlsaUpgrade-1.0.x-rev-1.17.sh -i
So when I run alsamixer after this it still says v1.0.18
Is there something I'm missing??
All three iec958 is unmuted.
I have runed iecset and verified that data value is set to audio
So I have done those parts
And the settings in xbmc is correct
* Audio Ougput -> Digital
* Dolby Digital AC3 Capable Receiver -> ON
* DTS Capable Receiver -> ON
* Audio Output Device -> default
* Passthrough Output Device -> iec958
[SOLVED]
All you need to do is add this (the file is now named .conf on the end:
sudo nano /etc/modprobe.d/alsa-base.conf
options snd-hda-intel model=6stack-dig
But I would still like to know what I'm doing wrong since I can't update alsa
great guide! it has helped me out alot...
i now have full hdmi a/v without dropping frames over vdpau.
my last remaining problem is extremely slow network speed. using wget, i can only pull down about 20k/s... even using sftp over a local connection, it maxes out around 40 k/s. obviously this makes streaming over SMB impossible. Same thing if i just boot up from the live cd. am i missing something or should i just get a separate network card?
thanks!
Step 16 fails for me under Live 9.04.1
Everything seems to work properly up to that point.
Reading through the thread, I tried updating libcdio-dev (as suggested in post 62) but it said I'm already at the latest version...
Here's what's happening... Any help would be greatly appreciated.
(T: XBMCLive)xbmc@XBMCLive:~/XBMC$ sudo ./configure --prefix=/usr
configure: Ensuring config.guess and config.sub exist and is executable
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for ccache... none
checking for g++... g++
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for gawk... gawk
checking whether ln -s works... yes
checking whether make sets $(MAKE)... yes
checking how to run the C++ preprocessor... g++ -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking boost/shared_ptr.hpp usability... yes
checking boost/shared_ptr.hpp presence... yes
checking for boost/shared_ptr.hpp... yes
checking for main in -lGL... yes
checking for main in -lGLEW... yes
checking for main in -lGLU... yes
checking how to run the C preprocessor... gcc -E
checking mad.h usability... yes
checking mad.h presence... yes
checking for mad.h... yes
checking jpeglib.h usability... yes
checking jpeglib.h presence... yes
checking for jpeglib.h... yes
checking samplerate.h usability... no
checking samplerate.h presence... no
checking for samplerate.h... no
configure: error: Could not find a required library. Please see the README for your platform.
Reading somewhere else that a borked install of video card drivers might cause this... reinstalling nvidia drivers.
Nope... complete format and reinstall... same issue.
sudo apt-get install libsamplerate-dev
Still getting the same error message... just a little further down.
(T: XBMCLive)xbmc@XBMCLive:~/XBMC$ sudo apt-get install libsamplerate-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting libsamplerate0-dev instead of libsamplerate-dev
libsamplerate0-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 27 not upgraded.
checking samplerate.h usability... yes
checking samplerate.h presence... yes
checking for samplerate.h... yes
checking for main in -lmad... yes
checking for main in -logg... yes
checking for main in -lvorbis... yes
checking for main in -lvorbisenc... yes
checking for main in -lvorbisfile... yes
checking for main in -lfreetype... yes
checking for main in -lfontconfig... yes
checking for main in -lbz2... yes
checking for main in -lfribidi... yes
checking for main in -lsqlite3... yes
checking for main in -lmysqlclient... yes
checking for main in -lasound... yes
checking for clock_gettime in -lrt... yes
checking for main in -lpng12... yes
checking for main in -ljpeg... yes
checking for main in -lpcre... yes
checking for __lzo_init_v2 in -llzo2... no
checking for __lzo_init2 in -llzo... yes
checking for main in -lcdio... yes
checking for main in -lsamplerate... yes
checking for main in -lz... yes
checking for main in -lSDL... yes
checking for main in -lSDL_image... yes
checking for main in -lSDL_mixer... yes
checking for main in -ldl... yes
checking for main in -lresolv... yes
checking for main in -lenca... yes
checking for main in -ljasper... yes
checking for main in -lmms... no
Tarantulas Wrote:Still getting the same error message... just a little further down.
lol, how about read the readme as suggested?
You have to install libxtst-dev and libmms-dev too...
Anyway... this guide is way outdated as of today...
Well it wasn't my intention to offend you.
Part of the reason why I got the P5N7A-VM was based on this guide. I'm no expert on linux, so it was nice to see sort of a step by step to getting Live set up using this board with all the bells and whistles.
Just a suggestion, but if you're not willing to update the guide for new versions of Live, please do the following:
1) Edit and note on your original post what version of Live your guide does work with.
2) Add any additional steps needed to make the guide work that aren't part of what you already have in your original post.
3) Put in big bold letters at the top that you are no longer updating and supporting the thread.
