Full Version: XBMC Live on ASUS P5N7A-VM complete guide
Pages: 1 2 3 4 5 6 7 8
Finally, as promised recently, I put together a step-by-step guide on how do I got almost everything working on my ASUS P5N7A-VM, using XBMC Live as a base. Please note, that I am far not a Linux pro by any means, so all these are based on some basic Linux knowledge, endless readings of XBMC and ubuntu forums, and a lot of hands-on trying.
With motherboard, equipped with an E7300 C2D CPU, I am able to play killa sample with only 10-13 frame drops at the begining, so I don’t think overclocking to ~3Ghz is necessery.
Features are working:
- AUDIO over SPDIF or HDMI (including navigation sounds, stereo MP3s, DTS, etc)
- Automatically adjust refresh rate according to the refresh rate of the movie
- Plugins (finally)
- CPU Scaling
- Optional usplash change
Remaining issues:
- Suspend is not working (that would require new kernel)
- Shutdown splash is collapsed on this board, but this is the same with standard ubuntu installation as well (didn't find the reason yet)
- because of the 2GB space limit on XBMC Live root partition, XBMC rebuild from SVN is possible only once (after we install ASLA upgrade, there will be no space any more to do an other compilation of XBMC)
STEP1
Download and install XBMC Live 8.10 (I installed to an USB stick, but I would assume, the belows can be used in case of HDD install as well).
STEP2
Download the newest nvidia linux driver from nvidia.com (the file name is „NVIDIA-Linux-x86-177.82-pkg1.run” today)
STEP3
Download ALSA upgrade script (AlsaUpgrade-1.0.x-rev-1.15.tar) from here:
http://ubuntuforums.org/showthread.php?t=962695
STEP4
Untar the ALSA upgrade sript somehow (eg. Total Commander has a built in feature for this), than you will get a file, named: AlsaUpgrade-1.0.x-rev-1.15.sh
STEP5
Make a new dir and name it „install” on the flash drive and copy over the freshly downloaded nvidia driver and ALSA upgrade srcipt into this dir.
STEP6
Copy over the syslinux.cfg (follow in a separate post) to the root of the flash drive to avoid the need of choosing nvidia manually in XBMC Live boot menu.
If you also want to change the splash screen:
STEP7
Download the choosen one, most probably from duduke. His blog is here
STEP8
Make a subdir in the above created "install" dir and name it to "splash". Unzip the downloaded splash zip into this folder.
STEP9
Boot into XBMC Live, than quit from XBMC (choose exit XBMC in the shutdown menu)
login on the console or ssh in remotely as per your convinience, using the user/pass: xbmc/xbmc
First of all, update the repos, and install all prerequisites using:
STEP10
#sudo apt-get update
STEP11
#sudo apt-get install make g++-4.1 gcc-4.1 libsdl1.2-dev libsdl-image1.2-dev libsdl-gfx1.2-dev libsdl-mixer1.2-dev libsdl-sound1.2-dev libsdl-stretch-dev libfribidi0 libfribidi-dev liblzo1 liblzo-dev libfreetype6 libfreetype6-dev libsqlite3-0 libsqlite3-dev libogg-dev libasound2-dev python-sqlite libglew1.5 libglew1.5-dev libcurl3-dev g++ gawk x11proto-xinerama-dev libxinerama-dev libxrandr-dev libxrender-dev pmount libmad0-dev libtre-dev libogg-dev libvorbis-dev libmysqlclient15-dev libhal1 libhal-dev libhal-storage1 libhal-storage-dev libpcre3-dev subversion libjasper-dev libjasper1 libfontconfig-dev libbz2-dev libboost-dev libtool nasm libfaac-dev libenca-dev automake cmake libxt-dev libxmu-dev gperf unzip libpng12-dev libjpeg62-dev bison libpulse-dev wget build-essential linux-headers-`uname -r`
Obviously it is a bit long to type in from the console, that’s why it would be more convinient to use ssh for that. (than you can use copy-paste). (I tried to use build dependencies from the repo, but I have difficulties with that, that’s why I recommend this manual way)
To upgrade nvidia driver:
STEP12
#sudo sh /mnt/install/NVIDIA-Linux-x86-177.82-pkg1.run
In the nvidia installer: accept the Licence agreement, choose „YES” for „No precompiled kernel interface...”, choose „OK” for „No matching precompiled kernel interface...”, than choose „NO” to update X configuration file, than finally „OK” again at the end.
To update XBMC to the latest SVN
STEP13
#cd $HOME
STEP14
#svn checkout https://xbmc.svn.sourceforge.net/svnroot/xbmc/branches/linuxport/XBMC
Accept the certificate permanetly with „P”
Wait for downloading XBMC source files, might be long time, depend on your Internet connection. After it downloaded:
STEP15
#cd XBMC
STEP16
#./configure --prefix=/usr
STEP17
#make –j2 [b](use only „make” in case you don’t have a dualcore CPU)[/b]
This is again, can takes a bit more of time, depend on your CPU speed. After it has compiled:
You have to preserve a file from the original XBMC Live system directory in order to have python (plugin) capabilities later:
STEP18
#sudo mv /usr/share/xbmc/system/python/python24.zip /mnt/install
STEP19
#sudo rm -r /usr/share/xbmc
STEP20
#sudo make install
STEP21
#sudo mv /mnt/install/python24.zip /usr/share/xbmc/system/python/
You will need to delete the source files (free up some disk space for next steps)
STEP22
#sudo rm -r /home/xbmc/XBMC
Now it’s a good time to an interim check if everything went OK, so reboot the system:
STEP23
#sudo reboot
STEP24
After the reboot, go to the shutdown menu in XBMC and check system info for compilation date. If it’s today, than you updated successfully.
STEP25
Than quit from XBMC (choose exit XBMC in the shutdown menu) again and log in, as in the very begining. To check if nvidia driver update was OK:
#grep -i "x driver" /var/log/Xorg.0.log
You will see the driver version here.
I hope, everything is fine, than we can continue with the ALSA upgrade.
To upgrade ALSA and enable digital (SPDIF or HDMI sound):
STEP26
#sudo /mnt/install/AlsaUpgrade-1.0.x-rev-1.15.sh -d
STEP27
#sudo /mnt/install/AlsaUpgrade-1.0.x-rev-1.15.sh -snap
STEP28
#sudo /mnt/install/AlsaUpgrade-1.0.x-rev-1.15.sh -i
Now, you have to edit the following file, using nano for example:
STEP29
#sudo nano /etc/modprobe.d/alsa-base
and add this line to the end:
options snd-hda-intel model=6stack-dig
than run alsamixer:
STEP30
#alsamixer
Note that you should see Alsamixer v1.0.18 in the title.
Navigate right with cursor keys until IEC958 and unmute all of them (IEC958, IEC958-D, IEC958-1) with „M” key. You should see in case of all IEC958 a „00” in green background. Press „ESC” to quit from alsamixer.
If you wish to enable CPU scaling feature:
First of all, don’t forget to enable it in the BIOS
STEP31
#sudo apt-get powernowd
Reboot the computer:
STEP32
#sudo reboot
STEP33
After booted into XBMC switch to „digital” audio output, than choose the AC3 and DTS capabilities according to your receiver.
For SPDIF: leave audio output device: default and passthrough on IEC958
For HDMI: change both audio output device and passthrough to hdmi (you will loose analog sound eg. navigation sound in case of hdmi)
Configure xorg.conf for proper modes to benefit from auto refresh:
STEP34
This is not an easy part and can differ from display to display.
In my case I configured 3 modes for my FullHD plazma screen, I post the result in a separete post. If you a properly working xorg.conf, than just copy it over to the „config” dir of your flash drive and you are done.
If you want to change the splash screen (thanks to erix):
STEP35
#cd /mnt/install/splash/
STEP36
#sudo apt-get install libusplash-dev
STEP37
#sudo make
STEP38
#cp /mnt/initrd0.img /mnt/install/splash
STEP39
#mv initrd0.img initrd0.gz
STEP40
#sudo gunzip initrd0.gz
STEP41
#mkdir tmp
STEP42
#cd tmp
STEP43
#sudo cpio -id < ../initrd0
STEP44
sudo cp /mnt/install/splash/xbmc-splash.so usr/lib/usplash/usplash-artwork.so
If you want to change to resolution of the splash, than
STEP45
sudo nano etc/usplash.conf
change the resolution and save the file.
STEP46
#find . | cpio --create --format='newc' > ../initrd0
STEP47
cd ..
STEP48
#sudo gzip initrd0
STEP49
#mv initrd0.gz initrd0.img
STEP50
#sudo mv initrd0.img /mnt/
STEP50
#sudo cp xbmc-splash.so /usr/lib/usplash/XBMC-theme.so
Now, as a cleanup, you might want to delete the temp, source dirs:
STEP51
#sudo rm -r /mnt/install/
STEP52
#sudo rm -r /usr/src/Alsa-1.0.18a/
Syslinux.cfg
default 1
prompt        1
timeout        1
# CONSOLE        0
# nVidia
label 1
  kernel vmlinuz
  append initrd=initrd0.img boot=usb quiet splash xbmc=nvidia
# AMD
label 2
  kernel vmlinuz
  append initrd=initrd0.img boot=usb quiet splash xbmc=amd
# Intel
label 3
  kernel vmlinuz
  append initrd=initrd0.img boot=usb quiet splash xbmc=intel
#MkUSB
label 0
  kernel vmlinuz
  append initrd=initrd0.img boot=usb quiet splash xbmc=mkusb
#Safe mode
label safe
  kernel vmlinuz
label toramintel
  kernel vmlinuz
  append initrd=initrd0.img boot=usb quiet splash xbmc=intel,boottoram
label toramnvidia
  kernel vmlinuz
  append initrd=initrd0.img boot=usb quiet splash xbmc=nvidia,boottoram
label toramamd
  kernel vmlinuz
  append initrd=initrd0.img boot=usb quiet splash xbmc=amd,boottoram
xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  ([email protected])  Tue Nov  4 14:07:17 PST 2008
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
    RgbPath         "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
#    VendorName     "Unknown"
#    ModelName      "Unknown"
    Option         "DPMS"
    Modeline "[email protected]" 74.160 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
    Modeline "[email protected]" 148.500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
    Modeline "[email protected]" 148.350 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
    HorizSync       15.0 - 68.0
    VertRefresh     23.0 - 61.0
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "NoLogo"
    Option         "DynamicTwinView" "false"
    Option         "AddARGBGLXVisuals" "True"
    Option        "ExactModeTimingsDVI" "True"
    SubSection     "Display"
        Depth       24
    Modes       "[email protected]" "[email protected]" "[email protected]"
    EndSubSection
EndSection
haven't tried it(don't have a P5N7A-VM, but I want one.), but nice going with the guide!
Very Nice guide olympia.
If you want more space on the root partition download gparted live cd. It can resize the partitions created by the xbmc live installer. I made my sda1 partition 3.5gb larger and replaced the ext3fs.img with a larger one. You have have to manually make it bootable again by running syslinux.exe in windows but thats no problem. Bare in mind all changes made in the current ext3fs.img will be erased. I've only tested this with a hd install not flash drive.
To make a larger ext3fs.img in linux.
dd if=/dev/zero of=ext3fs.img bs=1M count=3500
mkfs.ext3 ext3fs.img -F
You can replace count= 3500 to whatever size although the sda1 partition is formatted in fat32 so i think it has a 4gb size limit(could be wrong about this).
cheers
Thanks for the really nice guide!!! Im wondering over sound to HDMI, you suggest:
olympia Wrote:STEP31
Why not create a file in /home/xbmc/.asoundrc and insert:
pcm.dmixer {
   type dmix
   ipc_key 1024
   ipc_key_add_uid false
   ipc_perm 0660
   slave {
      pcm "hw:0,3"
      rate 48000
      channels 2
      format S32_LE
      period_time 0
      period_size 1024
      buffer_time 0
      buffer_size 4096
pcm.!default {
   type plug
   slave.pcm "dmixer"
And in XBMC audio settings:
digital
on/off
on/off
default
default
from this post:
http://forum.xbmc.org/showpost.php?p=259...stcount=41
This way you also get menu sound or is there a drawback with this metod?
Happy new year!
/O
SpiffBB Wrote:Thanks for the really nice guide!!! Im wondering over sound to HDMI, you suggest:
Primarily I don't have hdmi audio setup, I just tested on my TV set, so it wasn't a major issue to me (I am using SPDIF). Anyway, thank you for the suggestion.
@harryzimm
Thank you for this also, i will give it a try, once I figured out the plugin (python) problem. Does plugins works for you after a manual compilation on XBMC Live from source?
The guide has been revised:
- Plugins are working now!
- Some steps was consolidated
- CPU scaling added
I will play later with haryzimm's suggestion concerning resizing, but the real pain is to miss suspend on this kernel. That's the reason I am experimenting further with building a linux base manually based on intrepid (suspend works fine on that).
Thanks for the tutorial and it works just fine for me except I cannot get stereo sound to work. I think it worked the first time but after a reboot it was gone. Dolby Digital and DTS works just fine.
This is what aplay shows as playback devices
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 0: ALC1200 Analog [ALC1200 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 1: ALC1200 Digital [ALC1200 Digital]
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 3: NVIDIA HDMI [NVIDIA HDMI]
  Subdevices: 1/1
In AlsaMixer IEC958, IEC958 D and IEC958 1 are all green with two O's showing.
Any idea what might be wrong?
EDIT:
SOLUTION: Inside XBMC i changed output from "default" to "IEC958" and then it worked. No clicking sound anymore when I arrow up/down in menues but it is no big deal. Don't know why it worked just once....
Interesting.
If I understand well, you are also using SPDIF and not HDMI for audio.
What do you use for testing stereo?
Yes I use SPDIF.
For testing stereo I use random mp3 files and some XVID movies with stereo sound.
hebjor Wrote:Yes I use SPDIF.
try turning the volume up on one or your iec958 channels in Alsamixer. I know they are digital and it is not suppose to matter, but some DO.
Dave
The method to change usplash theme is added (thanks to erix)
I wish I could solve to suspend on 8.04 with this board, until Intrepid playback performance issues is tracked down....
i got a problem with the sound from playback xvid/mp3 files, the sound is hanging,delaying.. sometimes short clear then hanging again like in a room Sad
alsamixer shows me only AlsaMixer v1.0.15 and not .18 dunno why..
Yes I use SPDIF
dirtylion Wrote:i got a problem with the sound from playback xvid/mp3 files, the sound is hanging,delaying.. sometimes short clear then hanging again like in a room Sad
Yes I use SPDIF
Than alsa is not got upgraded, I would assume, than can cause the problem. I had major sound quaility issues with 1.0.15 as well....
