Full Version: Apple TV is frozen.
I have a new ATV running lasted update from Apple. I loaded the patchstick. Ran the software updates in XBMC and Boxee. Restarted and everything was running fine until I changed the screen resolution in XBMC. I first changed to the full screen, which worked fine. Then I tried 480p and that's when I had problems. I restarted the ATV and when the menu comes up I can't scroll through the menu or access anything in my Apple TV.
Is there a fix for this?
Can I restore my ATV to original settings?
Help!
Software version 2.3
It is still visible in itunes.
I'm able to stream music through ATV.
It seems that the remote is not working. I get an amber light on ATV when I use remote. Tried another remote, same problem.
Finally did a factory restore. Everything is working fine now.
Great. :-)
