Full Version: [RELEASE] MythBox for XBMC - a MythTV Front-end Python Script for XBMC
I'm wondering if it is possible for a plugin/script to access a "media source". If so, Mythbox could be modified to be able to use a media source for accessing the mythtv recordings directory... this would get around the need to mount the directory externally to xbmc, and also to develop a script to do that mount.
Is it possible to disable the welcome/splash screen? Just the black background and white mythbox whenever I enter the add-on.
srose99ca Wrote:I'm wondering if it is possible for a plugin/script to access a "media source". If so, Mythbox could be modified to be able to use a media source for accessing the mythtv recordings directory... this would get around the need to mount the directory externally to xbmc, and also to develop a script to do that mount.
I don't believe that Mythbox mounts anything. It sends a request to the MythTV server which then streams the file.
Sorry, I guess I wasn't very clear. I can mount the mythtv recordings directory as a "media source" in XBMC, but can't mount it as a mount point out side of XBMC. As Mythbox seems to only want to accept a mount point as the location of the recordings directory, this means that I can't get Mythbox running on an ATV2.
I think that if it is possible to modify Mythbox to be able to utilize a "media source" as the location of the mythtv recordings, Mythbox would work on the ATV2.
Cheers,
Steve
I installed .24 mythubuntu and was able to access it using myth plugin in XBMC dharma. I am aware that this plugin does not work **fully** in .24 - Are there any plans to support 0.24 in the future? Is this development actively pursued?
Whoever developed this plugin - hats off! now XBMC can be one media center for ALL my needs
vskatusa Wrote:I installed .24 mythubuntu and was able to access it using myth plugin in XBMC dharma. I am aware that this plugin does not work **fully** in .24 - Are there any plans to support 0.24 in the future? Is this development actively pursued?
I think full 24 support will come as part of the PVR enhancement. There was some thought that 23.1 wouldn't work properly but it turns out the code was tolerant enough it wasn't a problem. 23.1 is where Mythtv changed their version ID system which 24 uses.
More info: http://trac.xbmc.org/ticket/11177
I'm working on a new skin for mythbox for Night(SVN only sorry!).
Here's one screen shot. (WIP!)
There are two things I can't figure out.
First where are the X,Y positions of show title, episode titles in TV GUIDE? I can't seem to find them in the tvguide.xml.
Second I can't seem to find the font size deceleration for TV shows in livetv.xml. Any ideas?
EDIT: I don't have any tuners on my Coding machine, just mythtv installed so it not showing anything is expected.
Having an issue related to the Aeon MQ2 theme, but only with Mythbox and I wonder if anyone here can help, as the Aeon MQ 2 thread is rather difficult to get help with as it moves too fast so I'd thought I'd give it a try here.
I posted here: http://forum.xbmc.org/showpost.php?p=750...count=3142
Also having an issue where randomly at the main screen (recent recordings) if I hit C for context menu to be able to delete the recording XBMC crashes out in a blink.
I'm seeing a problem when watching a recording as it is recording. FYI watching a completed recording works fine.
The recording is not being scanned for commercial skips while being watched (scan occurs after the recording is completed).
The recording plays for 5-6minutes and then stops. I then have to start playing it again and skip forward to where I was when it stopped. This happens 4-5 times in a half hour program.
Is this a known problem?
Further info on my prior post -
Here's a snippet of my log where I think things start to go wrong:
PHP Code:
17:52:55 T:2966162288 M:1295892480 WARNINGCDVDMessageQueue(audio)::Get asked for new data packetwith nothing available
17
:52:56 T:2966162288 M:1295908864 WARNINGCALSADirectSound::GetSpace get space failederr: -32 (Broken pipe)
18:05:00 T:2966162288 M:1279860736 WARNINGPrevious line repeats 3 times.
18:05:00 T:2966162288 M:1279860736 WARNINGCDVDMessageQueue(audio)::Get asked for new data packetwith nothing available
18
:05:01 T:2860325744 M:1279860736 WARNINGCDVDMessageQueue(video)::Get asked for new data packetwith nothing available
18
:05:01 T:2955672432 M:1279860736  NOTICECDVDPlayer::OnExit()
18:05:01 T:2955672432 M:1279860736  NOTICEDVDPlayereofwaiting for queues to empty
18:05:01 T:2955672432 M:1279860736  NOTICEDVDPlayerclosing audio stream
18
:05:01 T:2955672432 M:1279860736  NOTICEClosing audio stream
18
:05:01 T:2955672432 M:1279860736  NOTICECDVDMessageQueue(audio)::WaitUntilEmpty
18
:05:01 T:2955672432 M:1279860736  NOTICEWaiting for audio thread to exit
18:05:01 T:2966162288 M:1279860736  NOTICEthread endCDVDPlayerAudio::OnExit()
18:05:01 T:2955672432 M:1279860736  NOTICEClosing audio device
18
:05:01 T:2955672432 M:1279860736  NOTICEDeleting audio codec
18
:05:01 T:2955672432 M:1279860736  NOTICEDVDPlayerclosing video stream
18
:05:01 T:2955672432 M:1279860736  NOTICEClosing video stream
18
:05:01 T:2955672432 M:1279860736  NOTICECDVDMessageQueue(video)::WaitUntilEmpty
18
:05:01 T:2955672432 M:1279860736  NOTICEwaiting for video thread to exit
18:05:01 T:2860325744 M:1279860736   ERRORGot MSGQ_ABORT or MSGO_IS_ERROR return true
The full log is here: http://pastebin.com/ZAQRZ0L4
Can i record iptv using this?
TugboatBill Wrote:Further info on my prior post -
PHP Code:
17
18
18
18
18
18
18
18
18
18
18
Bueller? Bueller?
Addtl notes: Today I tried simultaneous recording 2 programs (HD & SD) and watching another (HD). Worked fine, so this problem only occurs when watching a program as it records and is not directly resource related.
This internal PCI express card made by Cetoncorp can record 4 channels of cable programming at one time including premium channels. It is currently only available for Windows. Any interest in getting this to work in XBMC?
Take a look.
http://www.cetoncorp.com/buy.php
The world’s first multi-tuner PC card for digital cable
The Ceton InfiniTV 4 is the world's first multi-tuner PC card for watching digital cable TV on the PC, including support for premium cable channels. It enables Media Center PCs to play or record up to four live channels of HDTV at once, and stream live HD channels or recordings to multiple HDTVs throughout the home, all from a single cable connection and a single CableCARD™.
Replace your cable set-top boxes and their costly monthly rental fees and enjoy premium cable TV throughout the home, all from a single PC. With the Ceton InfiniTV 4 your Media Center PC becomes a complete entertainment platform for all your media, including premium cable TV.
Four Live HD Channels At Once
Watch and/or record four live channels of standard-definition or high-definition TV simultaneously, including all your favorite premium and encrypted cable channels. * Four, dual ATSC/QAM 64/256 tuners
* CableCARD M-Card DRM Processor
* Open Cable Unidirectional Receiver Specification - OC-SP-OCUR-I08-081114
* Digital Receiver Interface Specification - OC-SP-DRI-I03-090206
* CableCARD Copy Protection 2.0 Specification - OC-SP-CCCP2.0-I10-090904
* CableCARD Interface 2.0 Specification - OC-SP-CCIF2.0-I20-091211
* Digital Cable Network Interface Standard - ANSI/SCTE 40 2004
Requirements
* Microsoft Windows 7 Home Premium, Windows 7 Professional, Windows 7 Enterprise, or Windows 7 Ultimate
* 2.0 GHz or faster CPU minimum, either 32 bit (x86) or 64 bit (x64) – 2.7 GHz or faster dual-core CPU is recommended
* 2 GB of RAM minimum – 3 GB or more is recommended
* 1 PCIe slot, which can be either an x1, x4, x8, or x16 type slot
* HDCP compliant on-board graphics or graphics card
* HDMI out, or DVI out with separate audio out
* Multi-Stream CableCARD™ (M-Card) – available from your local cable provider
* Digital cable subscription from a U.S. cable provider
Does mythtv work as well on windows vs Linux? Also since ceton requires the playon plugin to decode I doubt it'll work with anything else.
There is a version of Mythtv for windows. I want to avoid using Windows as the ceton product would work nicely in a live version of XBMC. Not to mention the additional licensing expense.
My understanding of the decoding it takes place on the add on card completely independent of Windows or the O.S.
