(2011-09-18, 16:18)nojstevens Wrote: [ -> ]Hello,
I have this working really well and reliable with a mythbuntu backend and XBMC/mythbox 1.0.4 front end for my HDHomeruns. However, it will not tune my HD PVR.
If I load mythfrontend on Mac or linux then I can tune the HD PVR very reliably, I am using Firewire channel changing. All works great, but on the Mythbox it says 'Buffering' then stops after 6 seconds. HDHomerun says Buffering then plays after 6 seconds.
I am thinking this is a timeout issue as the channel takes a while to change on the backend. I also tried playing this inside XBMC using the myth:// protocol - again HDHomerun streams play but HD PVR will not.
Does anyone have any advice for me on what I have to change on my XBMC to get it to stream my HD PVR source? So close to having it perfect....
(I should add, if I schedule a recording on the HD PVR I can watch it on Mythbox)
Jon
Jon,
I think I'm having the exact same problem as you with LiveTV and my HD PVR. I'm actually using an IR blaster for channel changing, and it takes about 10 seconds for the change to finish. By the time this finishes, it appears that XBMC has timed out the stream. For the record, playback of existing recordings from my HD PVR work perfectly under XBMC - using either the built-in myth protocol or the MythBox add-on.
If I simply change the mythtv backend to used /bin/true as the channel change script, LiveTV works perfectly. Obviously, the channel has to be changed manually, but this might be a good test for you to see if this works. This behaviour has convinced me that I'm running into some type of timeout condition. I posted a thread here (
Live TV with Mythtv and Hauppauge HD PVR) asking about mythtv timeouts before I found your post.
I'd be interested to hear if this "workaround" behaves the same on your end.
Does anyone use ACPI suspend with xmbc running on a mythtv-backend?
I currently have mythfrontend setup so that when it exits I get back to mythwelcome and mythbackend then will run a mythsuspend script to do suspend to RAM.
The important thing though is that it programs my RTC clock so that it wakes up in time for the next recording schedule.
I'm going to guess that if I just use XBMC's suspend feature, it will just suspend and my PC will not wake up for its next recording.
How does one do ACPI suspend with xbmc on a PC that is also running a myth backend?
Thanks,
Marc
Mythbox 1.1.0 + EDEN
Whenever I click on recordings I get a window pop up msg " cannot import name decodelonglong" - When I press the ESC key the popup vanishes...Any fix on this?
(2012-04-03, 00:56)vskatusa Wrote: [ -> ]Mythbox 1.1.0 + EDEN
I get the same problem. Not sure what the problem/fix is.
This message never appeared in the XBMC 10.1 + Previous version of mythbox
I just installed MythBox and when I go into my recordings, not all of them show up. I only see four recording and when I check MythTV itself it shows I have 9. In fact, the recording for one TV show aren't even showing up!
Is this a known bug, or have I likely mis-configured something? Let me know what additional info you need. :-)
-SilkBC
Does mythbox require an actual MythTV dedicated computer to use the tuner? Not sure how to use this with XBMC Eden and HDHomerun tuner no other computers or devices..
Is this just a remote control for something else?
After I create missing database I get: Table 'mythconverg.settings' doesn't exist
Yes, you need a working mythtbackend setup to use mythbox. You need to get mythtv working first.
Any news of mythbox support for myth 0.25?
I tried getting it to talk to myth 0.25, and as expected it did not work. I'm not sure if it's safe to just raisde the protocol number in the code, or not.
17:11:18 T:2841082736 NOTICE: MythBox: loggerIniFile = /home/mythtv/.xbmc/addons/script.mythbox/mythbox_log.ini
17:11:21 T:2841082736 ERROR: settings.py:222 | MainThread | Unsupported protocol: 72
File "/home/mythtv/.xbmc/addons/script.mythbox/resources/src/mythbox/settings.py", line 219, in verifyMythTVConnectivity
session = Connection(self, translator=self.translator, platform=self.platform, bus=EventBus(), db=db)
File "/home/mythtv/.xbmc/addons/script.mythbox/resources/src/mythbox/mythtv/conn.py", line 207, in __init__
self.db_init()
File "<string>", line 1, in <lambda>
File "/home/mythtv/.xbmc/addons/script.mythbox/resources/src/mythbox/mythtv/db.py", line 87, in inject_db
return func(*args, **kwargs)
File "/home/mythtv/.xbmc/addons/script.mythbox/resources/src/mythbox/mythtv/conn.py", line 215, in db_init
self.cmdSock = self.connect()
File "/home/mythtv/.xbmc/addons/script.mythbox/resources/src/mythbox/mythtv/conn.py", line 242, in connect
raise ProtocolException('Unsupported protocol: %s' % protocol.serverVersion)
ProtocolException: Unsupported protocol: 72
0.25 support should be in the official plugin soon, if you are in a rush though I have a branch at:
https://github.com/mitchcapper/mythbox
which I will keep up to date with whatever protocol changes I make.
Been using Mythbox for a while now and first off I'd just like to say a big thanks, it's an excellent plugin
I was wondering if it would be possible to have a small feature added to it, I'd like a watched notification, whether it be a tickbox as used in the rest of xbmc in Movies etc or something else I don't mind but it would be really useful to see which recordings have been watched and which haven't. I used to use Mythtv frontend to view recordings and it has a watched icon available within that so it seems to me the feature is supported by both Mythtv and xbmc so hopefully it wouldn't be too hard to implement, here's hoping anyway.
(2012-04-22, 04:13)dteirney Wrote: [ -> ]If anyone using MythBox is interested in being able to test some code changes that I've made to (in theory) support Myth 0.25 please have a look at:
http://forum.xbmc.org/showthread.php?tid=129021
Great!
Initially I installed from zip file, on top of my previous Mythbox (which was giving the protocol 72 error) and continued to get the error.
Then I de-installed Mythbox and re-installed from zip file.
This time it worked.
Many thanks.
(2012-05-02, 12:59)SilverLining Wrote: [ -> ] (2012-04-22, 04:13)dteirney Wrote: [ -> ]If anyone using MythBox is interested in being able to test some code changes that I've made to (in theory) support Myth 0.25 please have a look at:
Great!
Many thanks.
GROAN!
I spoke too soon. All the menus work and the test works but recordings don't play - no error mesage - just nothing happens.
Below is the relevant log file extract. It looks like it might be something to do with "unable to load file". I have checked and user01 is a member of the mythtv group so should have access to the recordings folder.
Any suggestions?
10:49:04 T:140511004489472 NOTICE: -->Python Interpreter Initialized<--
10:49:04 T:140511004489472 NOTICE: MythBox for XBMC
10:49:05 T:140511004489472 NOTICE: MythBox: loggerIniFile = /home/user01/.xbmc/addons/mitchcapper-mythbox-9016fc4/mythbox_log.ini
10:49:08 T:140511043421952 WARNING: Create - Unsupported protocol(script) in script://
10:49:09 T:140511353698176 ERROR: Texture manager unable to load file: /home/user01/.xbmc/userdata/addon_data/script.mythbox/cache/http/b4a563691342e4ed4abfa12ef354672b
10:49:09 T:140511353698176 ERROR: Previous line repeats 3 times.
10:49:09 T:140511353698176 ERROR: Texture manager unable to load file: /home/user01/.xbmc/userdata/addon_data/script.mythbox/cache/http/ec3d35c8222c2504b7f5687d471f9b40
10:49:15 T:140511353698176 ERROR: Previous line repeats 1 times.
10:49:15 T:140511353698176 ERROR: Control 700 in window 13002 has been asked to focus, but it can't
10:49:16 T:140511353698176 ERROR: Texture manager unable to load file: /home/user01/.xbmc/userdata/addon_data/script.mythbox/cache/http/6f22d2925ef25bb5d7196a59a957d04c
10:49:23 T:140511353698176 ERROR: Previous line repeats 1 times.
10:49:23 T:140511353698176 ERROR: Texture manager unable to load file: /home/user01/.xbmc/userdata/addon_data/script.mythbox/cache/channel/
10:49:28 T:140511353698176 NOTICE: DVDPlayer: Opening: myth://mythconverg:[email protected]:6543/recordings/1004_20120502205700.mpg
10:49:28 T:140511353698176 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
10:49:28 T:140511051814656 NOTICE: Creating InputStream
10:49:28 T:140511051814656 ERROR: GetControl - unable to connect to server on 192.168.2.13:6543
10:49:28 T:140511051814656 ERROR: CDVDPlayer::OpenInputStream - error opening [myth://mythconverg:[email protected]:6543/recordings/1004_20120502205700.mpg]
10:49:28 T:140511051814656 NOTICE: CDVDPlayer::OnExit()
10:49:28 T:140511051814656 NOTICE: CDVDPlayer::OnExit() deleting input stream
10:49:28 T:140511004489472 ERROR: player.py:78 | MainThread | onPlayBackStopped
File "/home/user01/.xbmc/addons/mitchcapper-mythbox-9016fc4/resources/src/mythbox/ui/player.py", line 76, in onPlayBackStopped
target.onPlayBackStopped()
File "/home/user01/.xbmc/addons/mitchcapper-mythbox-9016fc4/resources/src/mythbox/ui/player.py", line 312, in onPlayBackStopped
if self._tracker.isAlive():
AttributeError: 'BoundedEvictingQueue' object has no attribute 'isAlive'
10:49:28 T:140511353698176 NOTICE: CDVDPlayer::CloseFile()
10:49:28 T:140511353698176 NOTICE: DVDPlayer: waiting for threads to exit
10:49:28 T:140511353698176 NOTICE: DVDPlayer: finished waiting
10:49:35 T:140511353698176 ERROR: Texture manager unable to load file: /home/user01/.xbmc/userdata/addon_data/script.mythbox/cache/http/6f22d2925ef25bb5d7196a59a957d04c
10:49:37 T:140511353698176 ERROR: Previous line repeats 1 times.
10:49:37 T:140511353698176 ERROR: ClearBlock: Trying to clear non existent block /home/user01/.xbmc/addons/mitchcapper-mythbox-9016fc4
10:49:39 T:140511004489472 NOTICE: Before fanart shutdown
10:49:43 T:140511004489472 WARNING: util.py:237 | MainThread | TIMER: shutdown took 4.35 seconds
10:49:43 T:140511004489472 NOTICE: Before bus.publish
10:49:43 T:140511004489472 NOTICE: Before reaping
10:49:44 T:140511004489472 NOTICE: Before pools
10:49:44 T:140511004489472 NOTICE: Before logging shutdown
10:49:44 T:140511004489472 NOTICE: .
10:49:45 T:140511353698176 ERROR: ClearBlock: Trying to clear non existent block /home/user01/.xbmc/addons/mitchcapper-mythbox-9016fc4
10:49:46 T:140511043421952 WARNING: Create - Unsupported protocol(script) in script://
10:49:46 T:140511353698176 ERROR: Unable to locate window with id -10000. Check skin files
10:49:52 T:140511353698176 NOTICE: Storing total System Uptime
10:49:52 T:140511353698176 NOTICE: Saving settings
10:49:52 T:140511353698176 NOTICE: stop all
