Full Version: Anyway to make episode info scroll in Fanart view?
is there anyway to make episode info scroll in Fanart view?, im not sure if i'm doing something wrong but it is static on my screen and therefore you can't read all the txt
There is a setting in skin settings to scroll plot text does it not work ?
i cant see that setting in PM3HD
where is it located? , i will check
Settings --> Skin Settings --> General --> "Enable Auto Scrolling for Plot & Review"
I would like to see this also. I think he's talking about the fanart view in PMIIIHD, I think it could fit nicely in the upper right hand corner and be a function that could be turned off or on.
yeah thats the one in fanart view.
so i take it there is no option then lol
oh well something for the future, i will just check that option you mentioned though, but i think its already enabled!
Sorry to ask again, bu is this possible or do i need to wait for a new version?
lestat1977uk Wrote:Sorry to ask again, bu is this possible or do i need to wait for a new version?
Which PM are you talking about? PM3HD or PMIII? ...Its different for both.
As Jezz_X had Stated, in PM3HD its Settings --> Skin Settings --> General --> "Enable Auto Scrolling for Plot & Review" from the Home screen.
If you are using PMIII (AKA Project Mayhem III) it's Settings --> Skin Settings --> Custom --> "Enable Auto Scrolling for Plot & Review" from the home screen
Hope that Helps
Setting the auto scroll on in PM3-HD has no effect. At least for me.HuhSad
