Full Version: deleting source path on apple tv with cyberduck ?
Ok i manged to connect to my apple tv using cyberduck . I just want to delete some of the source path that i put in during the setup for the video files , but it seems impossibe to do with the apple remote and i can not hook up a mouse to my apple tv because it does not work . does anybody know where the source path links are located and how i can delete the ones i don't need anymore ? thanks for the help i LOVE the program so far,,
/Users/frontrow/Library/Application\ Support/XBMC/UserData/sources.xml
thank you very much for your answer , that fixed it :-)
