Full Version: Has anyone had success in using XBMC + NX
When I try, I get the error reported here http://trac.xbmc.org/ticket/5501
Note, I did not submit the ticket, it came up when querying my issue.
I am using XBMC svn revision 16904 on 32 bit Ubuntu Hardy with a nvidia card.
error from the terminal
media@media-desktop:~$ xbmc --version
Xlib: extension "XINERAMA" missing on display ":1007.0".
Segmentation fault (core dumped)
method return sender=:1.3 -> dest=:1.41 reply_serial=2
Ok, that must not be the cause because I get the same error when I ssh in but xbmc loads.
Any suggestions on a good x forwarder that works with xbmc?
Did you try ssh -X?
But be careful as it produces higher load on cpu.
I started with ssh. It takes 10 or 15 seconds to go from chose a menu choice.
That's right. Delay will noticeable increase.
No other ideas from me.
