2009-01-06, 15:54
I'm having problems playing ALL videos that have .IDX/.SUB subtitle files associated with them. Most of them take more than a couple seconds to buffer (which is really long!), then the audio starts playing for a couple of seconds, and then XBMC crashes. Renaming the subs to a different filename fixes the problem because XBMC is no longer loading them.
This problem only started happening recently. I did some testing, and it happens with both local files and networked files. The XBMC log from one session is 18MB and reports a MASSIVE error list after:
The list looks to be thousands of lines of errors, mainly consisting of the same lines repeated over and over several hundred times, including:
Anybody got any idea what's going on?
Quote:21:54:48 T:3944 M:2200444928 NOTICE: Opening Subtitle file: C:\Documents and Settings\Administrator\Application Data\XBMC\cache\subtitle.idx
22:01:36 T:816 M:2200334336 NOTICE: running thread: CDVDPlayerAudio:rocess()
Quote:22:01:36 T:2836 M:2186752000 WARNING: CDVDPlayer::CheckContinuity - stream wrapback detected (2)
22:01:36 T:2836 M:2112729088 WARNING: CDVDPlayer::CheckContinuity - stream wrapback detected (1)
22:01:36 T:2836 M:2112720896 WARNING: CDVDPlayer::CheckContinuity - resyncing due to stream wrapback (1)
22:01:44 T:2836 M:239636480 ERROR: CDVDDemuxFFmpeg::Read : Access violation at 0x77c47034: Writing location 0x00002313
22:01:44 T:2836 M:239628288 WARNING: CDVDPlayer::CheckPlayerInit(3) - Ignoring too large delay of 1739549666.666667
22:01:44 T:2836 M:239628288 ERROR: CDVDDemuxFFmpeg::Read : Access violation at 0x77c47034: Writing location 0x0000f1df
22:01:45 T:2324 M:242941952 ERROR: CDVDVideoCodecFFmpeg:ecode - avcodec_decode_video returned failure
22:01:45 T:816 M:242896896 NOTICE: Creating audio device with codec id: 86018, channels: 2, sample rate: 48000, no pass-through
22:01:45 T:816 M:242642944 WARNING: CWin32DirectSound::AddPackets - buffer underrun
22:01:48 T:2324 M:247717888 ERROR: CDVDVideoCodecFFmpeg:ecode - avcodec_decode_video returned failure
22:01:48 T:816 M:247697408 ERROR: CDVDAudioCodecLibFaad() : Bitstream value not allowed by specification
22:01:51 T:816 M:245432320 ERROR: CDVDAudioCodecLibFaad() : Gain control not yet implemented
