Full Version: System reboots when streaming from ccxstream server
Due to a rather slow response (when browsing folders and launching movies) using samba shares on my ubuntu server, I decided to try out a different stream server.
I installed ccxserver following the instructions of ignatz42 in the ubuntu forum:http://ubuntuforums.org/showthread.php?p=239721
After installing I found the share on my ATV immediately and file browsing was excelent without any delay. Most movies started quicker than using samba too. However, some movies will not start at all
I've included logs for one of these scenarios below.
Is anyone else experiencing problems with with streaming some ISO files from ccxstream server to the ATV? (the same files is playing as they should using samba)
-- ITEM NOT STARTED LOG --
13:03:52 T:2684407808 M: 8802304 DEBUG: CPlayerCoreFactor::GetPlayers(xbms://user:[email protected]:1400/Barn/AsterixVikingene.iso)
13:03:52 T:2684407808 M: 8802304 NOTICE: DVDPlayer: Opening: xbms://user:[email protected]:1400/Barn/AsterixVikingene.iso
13:03:52 T:2684407808 M: 8802304 WARNING: CDVDMessageQueue::Put MSGQ_NOT_INITIALIZED
13:03:52 T:43398144 M: 8810496 DEBUG: Running thread 43398144
13:03:52 T:43398144 M: 8810496 DEBUG: thread start, auto delete: 0
13:03:52 T:43398144 M: 8810496 NOTICE: Creating InputStream
13:03:52 T:43398144 M: 8806400 INFO: msg: libdvdnav: Using dvdnav version 0.2.0cvs from http://dvd.sf.net
13:03:52 T:43398144 M: 8806400 INFO: msg: libdvdread: Using libdvdcss version 1.2.9 for DVD access
13:03:52 T:43398144 M: 8798208 INFO: Stating open file
13:03:52 T:43398144 M: 8781824 INFO: msg: libdvdnav: vm: DVD Title: ASTERIX_NO
13:03:52 T:43398144 M: 8781824 INFO: msg: libdvdnav: Unable to find map file '/Users/frontrow/.dvdnav/ASTERIX_NO.map'
13:03:52 T:43398144 M: 8781824 INFO: msg: libdvdread: potential layer change. 1 zero sectors detected starting at 4!
13:03:52 T:43398144 M: 8781824 INFO: msg: libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions:
13:03:52 T:43398144 M: 8781824 INFO: msg: 1
13:03:52 T:43398144 M: 8781824 INFO: msg: 2
13:03:52 T:43398144 M: 8781824 INFO: msg: 3
13:03:52 T:43398144 M: 8781824 INFO: msg: 4
13:03:52 T:43398144 M: 8781824 INFO: msg: 5
13:03:52 T:43398144 M: 8781824 INFO: msg: 6
13:03:52 T:43398144 M: 8781824 INFO: msg: 7
13:03:52 T:43398144 M: 8781824 INFO: msg: 8
13:03:52 T:43398144 M: 8781824 DEBUG: msg:
13:03:52 T:43398144 M: 8781824 DEBUG: libdvdread: Attempting to retrieve all CSS keys
13:03:52 T:43398144 M: 8781824 DEBUG: libdvdread: This can take a _long_ time, please be patient
13:03:52 T:43398144 M: 8781824 INFO: msg: libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x00000128
13:03:52 T:43398144 M: 8777728 INFO: msg: libdvdread: Elapsed time 0
13:03:52 T:43398144 M: 8777728 INFO: msg: libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00000870
13:03:52 T:43398144 M: 8777728 INFO: msg: libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00014e2d
13:03:52 T:43398144 M: 8773632 INFO: msg: libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x0021e3ba
13:03:52 T:43398144 M: 8773632 INFO: msg: libdvdread: Elapsed time 0
13:03:52 T:43398144 M: 8773632 INFO: msg: libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x0021f859
13:03:52 T:43398144 M: 8773632 INFO: msg: libdvdread: Found 3 VTS's
13:03:52 T:43398144 M: 8773632 DEBUG: Open - Setting region mask ff
13:03:52 T:43398144 M: 8773632 NOTICE: DVDPlayer: playing a dvd with menu's
13:03:52 T:43398144 M: 8773632 NOTICE: Creating Demuxer
13:03:52 T:43398144 M: 8773632 INFO: msg: libdvdread: Invalid IFO for title 2 (VTS_02_0.IFO).
13:03:52 T:43398144 M: 8773632 DEBUG: libdvdnav: ifoOpenVTSI failed
13:03:52 T:43398144 M: 8773632 ERROR: Error getting next block: Encrypted or faulty DVD
13:03:52 T:43398144 M: 8773632 DEBUG: Playback has started
13:03:52 T:43398144 M: 8773632 NOTICE: CDVDPlayer::OnExit()
13:03:52 T:43398144 M: 8773632 NOTICE: DVDPlayer: eof, waiting for queues to empty
13:03:52 T:43398144 M: 8773632 NOTICE: CDVDPlayer::OnExit() deleting demuxer
13:03:52 T:43398144 M: 8773632 NOTICE: CDVDPlayer::OnExit() deleting input stream
13:03:52 T:43398144 M: 8773632 DEBUG: Playback has finished
13:03:52 T:43398144 M: 8773632 DEBUG: staticThread, deleting thread graphic context
13:03:52 T:43398144 M: 8773632 DEBUG: Thread 43398144 terminating
13:03:53 T:2684407808 M: 8794112 DEBUG: GetMovieId (xbms://user:[email protected]:1400/Barn/AsterixVikingene.iso), query = select idMovie from movie where idFile=181
13:03:53 T:2684407808 M: 8794112 DEBUG: GetEpisodeId (xbms://user:[email protected]:1400/Barn/AsterixVikingene.iso), query = select idEpisode from episode where idFile=181
13:03:53 T:2684407808 M: 8794112 DEBUG: GetMusicVideoId (xbms://user:[email protected]:1400/Barn/AsterixVikingene.iso), query = select idMVideo from musicvideo where idFile=181
13:03:53 T:2684407808 M: 8798208 ERROR: Playlist Player: skipping unplayable item: -1, path [xbms://user:[email protected]:1400/Barn/AsterixVikingene.iso]
13:03:53 T:2684407808 M: 8798208 WARNING: Attempt to set unplayable index -1
13:03:53 T:2684407808 M: 8798208 DEBUG: CGUIInfoManager::SetCurrentMovie()
13:03:53 T:2684407808 M: 8798208 DEBUG: GetMovieId (), query = select idMovie from movie join files on files.idFile=movie.idFile where files.idpath = 4294967295
13:03:53 T:2684407808 M: 8798208 NOTICE: CDVDPlayer::CloseFile()
13:03:53 T:2684407808 M: 8798208 WARNING: CDVDMessageQueue::Put MSGQ_NOT_INITIALIZED
13:03:53 T:2684407808 M: 8798208 NOTICE: DVDPlayer: waiting for threads to exit
13:03:53 T:2684407808 M: 8839168 NOTICE: DVDPlayer: finished waiting
13:03:53 T:2684407808 M: 8839168 DEBUG: LinuxRendererGL: Cleaning up GL resources
13:04:17 T:2684407808 M: 8941568 DEBUG: SECTION:UnloadDelayed(SECTION: LCODE)
13:04:19 T:2684407808 M: 8474624 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\players\dvdplayer\liba52-osx.so)
13:04:19 T:2684407808 M: 8474624 DEBUG: Unloading: liba52-osx.so
13:04:20 T:2684407808 M: 8486912 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\players\dvdplayer\libmpeg2-osx.so)
13:04:20 T:2684407808 M: 8486912 DEBUG: Unloading: libmpeg2-osx.so
13:04:21 T:2684407808 M: 8499200 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\ImageLib-osx.so)
13:04:21 T:2684407808 M: 8499200 DEBUG: Unloading: ImageLib-osx.so
13:04:22 T:2684407808 M: 8544256 DEBUG: SECTION:UnloadDelayed(SECTION: LIBXBMS)
13:04:22 T:2684407808 M: 8544256 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\players\dvdplayer\libdvdnav-osx.so)
13:04:22 T:2684407808 M: 8544256 DEBUG: Unloading: libdvdnav-osx.so
13:04:53 T:43084800 M: 8810496 NOTICE: ES: Client from 127.0.0.1 timed out
