2009-01-09, 21:21
I moved some files from one drive to another drive (the contents i moved included xbmc scripts, etc.). now, when i turn on my xbox, it does not load up xbmc. it simply loads up to an xbox screen with the xecutor logo on the bottom. the screen remains that way.
question is, i need to move the contents back into the original drive (i figure this would fix the problem). i don't have the xbox networked to my laptop. can i put a ftp program into a writeable cd, insert it into the xbox, play the ftp program from the cd in the xbox and move the contents back to its original drive? if not, how can i do so?
i no nothing about ftp or modding xboxes, i bought this xbox modded and i'm simply trying to find a simple solution.
