Jezz_X Wrote:lol guess you didn't read what I wrote proper
And yes I know the screenshot is window mode else you would not be able to tell its windows 7 it would just look like xbmc
XBMC info will report the OS installed (atleast mine does)
Jezz_X Wrote:In window mode it tends to stutter alot and use more cpu but my guess is thats the Aero interface and those small little windows being rendered slowing it down.
I have the same result with multiple screens, windowed mode is slower than fullscreen, and with multiple screens aero is still rendered when running it fullscreen, it's some bug with xbmc.
Video stutters in fullscreen mode only, plays fine when XBMC is windowed.
Running on 64bit Windows 7 build 7000, Intel E8500, Radeon 4850 with catalyst 8.12 drivers, 4GB RAM
http://pastebin.com/m3bd75295
Any help would be appreciated
Video stutters in fullscreen mode only, plays fine when XBMC is windowed or when any other window is overlaying the fullscreen mode.
Running on 64bit Windows 7 build 7000, Intel E8500, Radeon 4850 with catalyst 8.12 drivers & CCC, 4GB RAM
Stencil Wrote:Video stutters in fullscreen mode only, plays fine when XBMC is windowed or when any other window is overlaying the fullscreen mode.
i've merged this with the correct thread, next time, search first !
i have xbmc running fine in windows 7 64bit, but the python24.dll will not load.
has anyone got python working in windows 7 64 bit?
Nuka1195 Wrote:i have xbmc running fine in windows 7 64bit, but the python24.dll will not load.
Try copying msvcr71.dll and msvcp71.dll from your \xbmc\setup directory to the windows\system32 directory?
I've had problems before with the win32dll loader that xbmc uses not correctly finding them in that directory.
thanks, unfortunately, that didn't work.
does python load for you?
Try opening a cmd line, and tying this:
regsvr32 "c:\windows\System32\msvcr71.dll"
regsvr32 "c:\windows\System32\msvcp71.dll"
I just recently had the same problem under Vista x64 and XP x86 (I just reinstalled XP because of this problem and some sound issues). Python was working on XP, and then it just stopped working. Moving those dll's did the trick for me.
Check out this thread:
http://forum.xbmc.org/showthread.php?tid...t=imagelib
Use the Dependency Walker program to find out what dll's it can't find. It listed a few besides msvcp71.dll for me (an encryption dll and a java dll), which I'm assuming were located somewhere in xbmc.
thank you,
i tried putting them in the xbmc/system folder, they needed to be in the python subfolder of xbmc/system.
python works good now
About the various video problems on Win7 x64:
The beta/preview ATi drivers for x64 don't include OpenGL 2.0 drivers. You won't be able to launch XBMC with these drivers. The 8.12 vista x64 drivers - which do include the OpenGL 2.0 - evidently don't jive well with win7, which is causing problems.
Switching to win7 x86 and using the beta/preview drivers is probably the best option for now.
The new Catalyst 9.1 Drivers for Vista 64 seem to have fixed the problems I was having.
i installed the latest catalyst vista 64bit drivers on windows 7 64bit and I'm getting nothing but flickering in full screen mode..windowed mode works fine but full screen mode is unbearable...I'm on a DFI 790gx amd board with ati hd3300 integrated graphics. any help would be appreciated...
I used ATOM 330 + INTEL 945G +2G MEMORY
IN XP OR VISTA XBMC 8.1 IS OK
BUT IN WINDOWS 7 B7000
IT HAVE SOME ERROR INFO ON STARTING XBMC.EXE
ADDRESS 0X00000000 IS CAN;T BE READ 0X00000000......
Hi everyone. I found this xbmc forum thread from a google search as I have been having a terrible time with the fullscreen flickering on Windows 7.
I have a fix for it (taken from overclock.net--props to micam93 who found it):
http://www.overclock.net/windows/458892-...ost5634802
Grab RivaTuner and:
Reinstalled XBMC and fullscreen mode is now flicker free!
