2009-06-24, 08:46
neurosis13 Wrote:try another player to norrow the problem down.
Same problem with mplayer and zoomplayer.
Btw. i'm running windows7, could that be the problem?
tiben20 Wrote:The settings tab is useless this is just a project i started and i turned it into the iso thing you wanted ill make it easier for you
http://www.mediafire.com/?sharekey=ce5b3...8114394287
XbmcExternalPlayerController0.03.rar
the advanced settings have to be set this way
XbmcExternalPlayerController.exe is the external player.Code:<externalplayer>
<filename>C:\XbmcExternalPlayerController.exe</filename>
<args></args>
<forceontop>false</forceontop>
<hidexbmc>true</hidexbmc>
<hideconsole>false</hideconsole>
<hidecursor>false</hidecursor>
</externalplayer>
If your launching it with an argument its launching the process instead of showing the settings window.
If your taking a look to your xbmc.log you should see executew32 c:\pathto\XbmcExternalPlayerController.exe "c:\pathto.iso"
Ravazul Wrote:Hi Guys,
i use MPC as my external player. Everything works fine so far.
But i can only play one Video. After i close MPC an switch back to XBMC i cant get another video to play.
Enter/Return/Select works for navigating trough xbmc but does not start another file.
I tried a few builds of xbmc including the some svn (atm XBMC-Rev21192).
My advancedsettings.xml
<advancedsettings>
<video>
<defaultplayer>externalplayer</defaultplayer>
</video>
<externalplayer>
<filename>C:\Program Files\Media Player Classic\mplayerc.exe</filename>
<args></args>
<hidexbmc>false</hidexbmc>
<hideconsole>true</hideconsole>
</externalplayer>
</advancedsettings>
Changing forceontop etc. does not change anything.
Its really frustrating to close and restart XBMC after every video
Please HELP!
willcmuk Wrote:I'm no expert at this but I'll try to help since mine works fine.
You have nothing in the <args> settings, does this mean at the minute at the end of a film you're manually closing mpc-hc?
I have mine set as: <args>/fullscreen /close</args> which auto closes it when the films stops, you could try that maybe and see how you go on, because I've noticed if I have mpc-hc already open before I use xbmc the films wont play, so presumably your mpc-hc is staying open once the film has finished and then when you revert back to xbmc it's not playing another film because it's already open?
Gamester17 Wrote:Any volunteers to help document this "External Player" feature in the XBMC wiki (the official XBMC Online Manual)?
http://wiki.xbmc.org/index.php?title=Adv...ttings.xml
Please register an account with the same name as your forum account and send me a PM requesting ninja access
http://wiki.xbmc.org/?title=XBMC_Online_Manual
tiben20 Wrote:Its on the way gamester17 i wrote every information needed to write the documentation to to ashlar and he will write the manual for this.
ps:You might have to add a page for playercorefactory.xml
moby-uk Wrote:Great.you can verify this its what i sended ashlar
@ashlar, let me know if you need a review or have any questions on the Babylon bits or the new playercorefactory stuff.
Possible rule:
the first 6 rule are boolean value(true or false)
-internetstream
-audio
-video
-dvd
-dvdfile
-dvdimage
the 4 next rule are string and your allowed to use regular expression too match the current
playing file.
-filetypes
ex: <rule filetypes="..i" player="externalplayer" />
**this rule would play every file which as the extension ending with "i"
"a.*" would play every file starting with a and so on
-protocols
this is related to zip rar stacked files url .......
-mimetypes
example:video/x-flv|video-flv|audio/aacp|application/sdp
-filename
the file name could be used like this filename=".*x264.*"
this will play every file containing x264
-player
the player name of the player
notes: you need to use the | for multiple value example: "avi|wmv"
you can also use filename="!(.*x264.*)" player="externalplayer" this is going to play every file with external player
exept the one with x264 in it
moby-uk Wrote:@puddney - this should fix setting the watched flag
moby-uk Wrote:I've just posted a build here which I'd greatly appreciate some testing of [I know there's probably something broken in libGoAhead (whatever that does) as it didn't compile cleanly for me but shouldn't affect the external player bits]I tried this, with debug activated the fps drawn went at intervals of a couple of seconds from around 60 to more than 500. The news ticker accelerated as well with the same rythm and even the bouncing square in video calibration.
