Has anyone setup with PowerDVD 15 Ultra yet? I upgraded but haven't gotten around to trying.
Want it auto play all my bd.iso and 3d bd.iso files. Version 14 I couldn't get it to auto start to keep simple for family. Also didn't auto detect with content was 3d. Has to manual change to 3d in PowerDVD.
(2015-05-13, 18:34)rmilyard Wrote: [ -> ]Has anyone setup with PowerDVD 15 Ultra yet? I upgraded but haven't gotten around to trying.
I finally managed to get PDVD14 to work flawlessly using Elaborate Bytes as a virtual DVD player. I amended the code to point at the Classic exe file rather than the Cinema exe as I just couldn't get it to work properly.
I recently tried PDVD15 (trial version) hoping the integration of ISO playback would negate the requirement to use Elaborate Bytes. However I just couldn't get it to work despite spending hours messing around with the xml code and batch file. I tried looking for a virtual drive exe within the PDVD15 folders but there doesn't appear to be one. Anyway I'm not sure whether I would want to use PDVD15 to "auto mount" ISO images in any event as it takes a while to load whereas Elaborate Bytes is almost instantaneous.
As stated, now that I've got PDVD14 to work flawlessly, I have no desire to upgrade. I'll post the playercorefactory & batch file code later. I presume you are running Kodi?
(2015-05-14, 10:06)Animal_Freeride Wrote: [ -> ] (2015-05-13, 18:34)rmilyard Wrote: [ -> ]Has anyone setup with PowerDVD 15 Ultra yet? I upgraded but haven't gotten around to trying.
I have been able to auto mount files with EB also. My issue is Kodi runs PowerDVD and shows Blu Ray mount but doesn't auto play the movie. When I used TMT6 in the past it would. I am thinking I am missing a /cmd argument or something.
Also issue I am seeing is PowerDVD doesn't detect if content of the Blu Ray is 3d or not. When I start it I need to selected (right click) and turn on 3d. TMT6 would just detect it. After doing that it plays after later if run a non 3d blu ray you need to do the same and turn it off.
(2015-05-14, 16:32)rmilyard Wrote: [ -> ] (2015-05-14, 10:06)Animal_Freeride Wrote: [ -> ] (2015-05-13, 18:34)rmilyard Wrote: [ -> ]Has anyone setup with PowerDVD 15 Ultra yet? I upgraded but haven't gotten around to trying.
This is what I use and runs perfect;
Playercore Code
<playercorefactory>
<players>
<player name="PowerDVD" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\(YOUR DETAILS HERE)\AppData\Roaming\Kodi\userdata\PowerDVD.bat</filename>
<args>"{1}"</args>
<hidekodi>false</hidekodi>
</player>
</players>
<rules action="prepend">
<rule filetypes="iso|bdmv|mpls" player="PowerDVD"/>
</rules>
</playercorefactory>
BAT File
Set file=%1
Set dummy=%file:iso=%
IF NOT %dummy% == %file% (GOTO playiso) ELSE (goto next)
:next
Set file=%1
Set dummy=%file:mpls=%
IF NOT %dummy% == %file% (GOTO plaympls) ELSE (goto playbdmv)
:playiso
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
"C:\Program Files (x86)\Cyberlink\PowerDVD14\PowerDVD.exe" E:
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 /u
GOTO end
:plaympls
set pth=%1
set pth=%pth:~1,-25%
"C:\Program Files (x86)\Cyberlink\PowerDVD14\PowerDVD.exe" "%pth%" exit
GOTO end
:playbdmv
set pth=%1
set pth=%pth:BDMV\MovieObject.bdmv=%
set pth=%pth:BDMV\index.bdmv=%
"C:\Program Files (x86)\Cyberlink\PowerDVD14\PowerDVD.exe" %pth% exit
GOTO end
:end
exit
(2015-05-17, 11:47)Animal_Freeride Wrote: [ -> ] (2015-05-14, 16:32)rmilyard Wrote: [ -> ] (2015-05-14, 10:06)Animal_Freeride Wrote: [ -> ]I finally managed to get PDVD14 to work flawlessly using Elaborate Bytes as a virtual DVD player. I amended the code to point at the Classic exe file rather than the Cinema exe as I just couldn't get it to work properly.
Playercore Code
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
</players>
</rules>
BAT File
Set file=%1
:next
Set file=%1
:playiso
GOTO end
:plaympls
set pth=%1
GOTO end
:playbdmv
set pth=%1
GOTO end
:end
exit
So I tried this with PowerDVD 15. The program loads but doesn't seem to mount the iso. So just sits there saying H: (My VCD) no disk.
This is the code I am trying right now:
powercorefactory:
<playercorefactory>
<players>
<player name="ISO_BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Ray\AppData\Roaming\Kodi\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
<hidexbmc>false</hidexbmc>
<hideconsole>True</hideconsole>
<warpcursor>none</warpcursor>
</player>
</players>
<!-- Bluray ISO -->
<!-- Bluray ISO/BDMV -->
<rule filetypes="iso|bdmv|mpls" player="ISO_BDMV_Player"/>
</rules>
PlayISO.bat:
Set file=%1
:next
Set file=%1
:playiso
"D:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
"C:\Program Files (x86)\CyberLink\PowerDVD15\Movie\PowerDVD Cinema\PowerDVDCinema.exe" H:
"D:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 /u
GOTO end
:plaympls
set pth=%1
"C:\Program Files (x86)\CyberLink\PowerDVD15\Movie\PowerDVD Cinema\PowerDVDCinema.exe" "%pth%" exit
GOTO end
:playbdmv
set pth=%1
"C:\Program Files (x86)\CyberLink\PowerDVD15\Movie\PowerDVD Cinema\PowerDVDCinema.exe" %pth% exit
GOTO end
:end
exit
When it runs the iso mounts and PowerDVDCinema starts. However it's not playing the H: drive. I am getting this:
As you can see it's looking at H: drive. Then I need to click the mouse and I will get this screen:
From here if I select H: this screen comes up:
If I click restart all works.
Also when I stop the movie it doesn't clock PowerDVD. I would like it to close to go back to Kodi.
If anyone knows what I might be doing wrong that would be great!
What rule in playercorefactory.xml will launch a 3D title only? Fwiw, I renamed the players so that it is how they appear in the Kodi menu so there's no confusion. I'm using 2 .bat files. 1 for 2D so it does not start NVidia stereoscopic and 1 for 3D so it does. Kodi menu shows dvdplayer, 2D and 3D players. 2D.iso's default to the 2D player (Perfect). 3D.iso's default to the 2D player (Not so perfect) I don't want to manually select a player for 2D or 3D so, I need the playercorefactory with a rule it understands to differentiate between 2D and 3D. Tagging the file name with '3D' doesn't work. Tagging the filetype with ssif doesn't work. Is it even possible?
This is a typical example of naming convention: Avatar (2009) .3D.iso
This makes no difference: Avatar (2009)_3D.iso
This makes no difference: Avatar (2009) .3DBluray.iso
This does not work:
<rule filename=".*3d.*" player="3D"/>
<rule filename=".*_3d.*" player="3D"/>
<rule filename=".*.3DBluray.*" player="3D"/>
<rule filename=".*3d.iso*" protocols="*3d.iso*" player="3D"/>
<rule filetypes="iso|bdmv|mplslssif" filename=".*3D.*" player="3D"/>
(EDIT) Never mind. Figured it out and totally perfected now. There is a definite order for rules by (precedence). Could have saved a lot of trial and error if this was in the External Player Wiki. Hope this helps others.
(2015-05-18, 20:50)rmilyard Wrote: [ -> ]This is the code I am trying right now:
powercorefactory:
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
</players>
<!-- Bluray ISO -->
</rules>
PlayISO.bat:
Set file=%1
:next
Set file=%1
:playiso
GOTO end
:plaympls
set pth=%1
GOTO end
:playbdmv
set pth=%1
GOTO end
:end
exit
I've already told you, DONT USE THE CINEMA EXE FILE!!! If you bothered listening to what I said it should work. I had the exactly the same issues you are experiencing. As you are trying to use PDVD15 (I'm using PDVD14), the code needs to be changed from 14 to 15 & E: to H: (your virtual drive).
Try this, it should be fine.
Playercore Code
<playercorefactory>
<players>
<filename>C:\Users\Ray\AppData\Roaming\Kodi\userdata\PowerDVD.bat</filename>
<args>"{1}"</args>
</player>
</players>
</rules>
BAT File
Set file=%1
:next
Set file=%1
:playiso
"C:\Program Files (x86)\Cyberlink\PowerDVD15\PowerDVD.exe" H:
GOTO end
:plaympls
set pth=%1
"C:\Program Files (x86)\Cyberlink\PowerDVD15\PowerDVD.exe" "%pth%" exit
GOTO end
:playbdmv
set pth=%1
"C:\Program Files (x86)\Cyberlink\PowerDVD15\PowerDVD.exe" %pth% exit
GOTO end
:end
exit
(2015-05-19, 21:53)Animal_Freeride Wrote: [ -> ] (2015-05-18, 20:50)rmilyard Wrote: [ -> ]This is the code I am trying right now:
powercorefactory:
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
</players>
<!-- Bluray ISO -->
</rules>
PlayISO.bat:
Set file=%1
:next
Set file=%1
:playiso
GOTO end
:plaympls
set pth=%1
GOTO end
:playbdmv
set pth=%1
GOTO end
:end
exit
Playercore Code
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
</players>
</rules>
BAT File
Set file=%1
:next
Set file=%1
:playiso
GOTO end
:plaympls
set pth=%1
GOTO end
:playbdmv
set pth=%1
GOTO end
:end
exit
This works for the most are. However since this is for my Home Theater projector room I would like to run the PowerDVD Cinema since works better with remotes.
(2015-05-20, 18:18)rmilyard Wrote: [ -> ] (2015-05-19, 21:53)Animal_Freeride Wrote: [ -> ] (2015-05-18, 20:50)rmilyard Wrote: [ -> ]This is the code I am trying right now:
powercorefactory:
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
</players>
<!-- Bluray ISO -->
</rules>
PlayISO.bat:
Set file=%1
:next
Set file=%1
:playiso
GOTO end
:plaympls
set pth=%1
GOTO end
:playbdmv
set pth=%1
GOTO end
:end
exit
Playercore Code
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
</players>
</rules>
BAT File
Set file=%1
:next
Set file=%1
:playiso
GOTO end
:plaympls
set pth=%1
GOTO end
:playbdmv
set pth=%1
GOTO end
:end
exit
I really don't understand why you say you are still having issues. I have a Sony projector set up connected via a Pioneer amp. I have a sound blaster external system which the optical output is connected to the amp. The sound blaster came with a remote which works with PDVD (in fact it's shipped with a PDVD software). However if you have an iPad/iPhone, you can control PDVD using an app. It's works really well and you can even use it as a track pad. Alternatively why not just buy a small keyboard with a built in track pad & use that as a remote?
There are so many options open to you but the fact is that the PDVD cinema mode option doesn't work particularly well.
Oh and a thanks for trying to help would be nice :-)
I upgraded to Kodi and wanted to have all my videos play using MPC and all streaming play with the internal player.
I created the following playercorefactory.xml file, I'm sure it worked for a while but for some reason now everything plays using MPC
<playercorefactory>
<players>
<player name="MPC-HC" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files (x86)\MPC-HC\mpc-hc.exe</filename>
<args>"{1}" /fullscreen /close</args>
<hidexbmc>true</hidexbmc>
<hideconsole>false</hideconsole>
<playcountminimumtime>900</playcountminimumtime>
</player>
</players>
<rule video="true" player="MPC-HC"/>
<rule name="streams" protocols="daap|smb|sop|rtv|rtsp|rtmp|http|https|rtmpe|rtsp|mms|rtp|pvr" player="DVDPlayer"/>
</rules>
I also tried modifying the code to:
<playercorefactory>
<players>
</player>
</players>
<rule internetstream="true" player="DVDPlayer" />
</rules>
Another odd thing is that if I switch the lines order, like this:
</rules>
MPC will not work and everything will be played using the internal player.
Any ideas?
Try this change:
<rule video="true" player="MPC-HC">
</rule>
</rules>
That works for me in a similar situation. Note the ending slash is gone from the MPC-HC line, and the internetstream line is a subset of the principal rule, which is now terminated by its own </rule>
The logic is: IF video is true, use MPC-HC, EXCEPT IF internetstream is true, then use DVDPLayer.
(2015-05-26, 22:46)pagali Wrote: [ -> ]Try this change:
</rule>
</rules>
Thank you, that worked perfectly
I tried using MPC-HC as external player using Kodi 4.2 on Windows 8.1 Ent x64
my playercorefactory.xml
<playercorefactory>
<players>
<filename>"C:\Program Files (x86)\K-Lite Codec Pack\MPC-HC64\mpc-hc64.exe"</filename>
</player>
</players>
<rule filetypes="mkv|mp4|avi" filename=".*" player="MPC-HC"/>
</rules>
Kodi log file shows
06:23:47 T:8204 NOTICE: CExternalPlayer::OpenFile: G:\601T\TV-Final\The Flash.2014.1080p\season01\The.Flash.2014.S01E01.Pilot.1080p.WEB-DL.DD5.1.AAC2.0.H.264-YFN.mkv
06:23:47 T:8464 NOTICE: Thread ExternalPlayer start, auto delete: false
06:23:48 T:8464 NOTICE: CExternalPlayer::Process: Player : "C:\Program Files (x86)\K-Lite Codec Pack\MPC-HC64\mpc-hc64.exe"
06:23:48 T:8464 NOTICE: CExternalPlayer::Process: File : G:\601T\TV-Final\The Flash.2014.1080p\season01\The.Flash.2014.S01E01.Pilot.1080p.WEB-DL.DD5.1.AAC2.0.H.264-YFN.mkv
06:23:48 T:8464 NOTICE: CExternalPlayer::Process: Content:
06:23:48 T:8464 NOTICE: CExternalPlayer::Process: Args : "{1}" /fullscreen /close
06:23:48 T:8464 NOTICE: CExternalPlayer::Process: Start
06:23:48 T:8464 NOTICE: CExternalPlayer::ExecuteAppW32: "C:\Program Files (x86)\K-Lite Codec Pack\MPC-HC64\mpc-hc64.exe" ""C:\Program Files (x86)\K-Lite Codec Pack\MPC-HC64\mpc-hc64.exe"" "G:\601T\TV-Final\The Flash.2014.1080p\season01\The.Flash.2014.S01E01.Pilot.1080p.WEB-DL.DD5.1.AAC2.0.H.264-YFN.mkv" /fullscreen /close
06:23:48 T:8464 NOTICE: CExternalPlayer::ExecuteAppW32 - Failure: 123
06:23:48 T:8464 NOTICE: CExternalPlayer::Process: Stop
06:23:48 T:8464 NOTICE: CExternalPlayer::Process: Showing Kodi window
Looks like Kodi passes the player's EXE name twice. Is there a way to fix this? or Did I do something wrong? Appreciate any help. Thx
EDIT:
I solved my problem by
1. Modifying playercorefactory.xml
<playercorefactory>
<players>
<filename>E:\WinData\App\XBMC\14.2\portable_data\userdata\PlayUsingMPCHC.bat</filename>
</player>
</players>
</rules>
2. Creating batch file: PlayUsingMPCHC.bat located on: E:\WinData\App\XBMC\14.2\portable_data\userdata
"C:\Program Files (x86)\K-Lite Codec Pack\MPC-HC64\mpc-hc64.exe" %1 %2 %3
This temporary solution works for me, in case you guys having the same problem.
How can I make it so that it automatically chooses the player in playercorefactory.xml, instead of having to choose it every time.
