Full Version: [Plugin Help]-alphabetical folder structure
Hello all,
Using Voinage's tut I am developing a Plugin for Indian movies website Rajshri.com. I fed it the link for letter 'A' page, and it is listing and playing (on windows) movies on first page of letter 'A'. I would like some help on listing all the pages in each alphabet and folder/directories for all the alphabets. Here is the starting link: http://www.rajshri.com/movies/Moviesaz.asp?letter=A
and here's the link for the plugin file: http://www.mediafire.com/?sharekey=58ade...b9a8902bda
Thanks for your help
Fixed the plugin for you and included comments on each section.
Good luck & thanks for using my tutorial - Sir.
Keep building.
http://www.mediafire.com/?sharekey=46407...b9a8902bda
Thank you very much, Voinage. It does work; there are just few issues that I will need to work out, but for now it does work. I will try to add some more features/categories and may be will release it.
hi, is there been a release on this, would like to check this out please?
thanks
