2009-01-11, 18:41
I installed AMT a while ago and had no problems with it. This most recent build I installed in and started the initial loading process when it was cancelled. Now when I try to go to AMT it opens, then displays "View: Media Info" in the status box and the entire XBMC process locks up. What information do I need so someone here can help me fix this? I've tried uninstalling AMT and reinstalling it, uninstalling it from the global /usr/share/xbmc/scripts folder and putting it in ~/.xbmc/scripts/My Scripts folder, it still does the same thing. Is there a cache somewhere or a database entry I need to delete to completely remove AMT?
If I run with debugging enabled, the only errors I get are:
the rest all seems fine?
09:54:56 T:3067623264 M: 18325504 WARNING: CUtil::GetMatchingSource... no matchi
ng source found for [?]
09:54:56 T:3067623264 M: 18325504 ERROR: CVirtualDirectory::GetDirectory(?) ma
tches no valid source, getting root source list instead
09:54:56 T:3067623264 M: 18325504 ERROR: CGUIMediaWindow::GetDirectory(?) fail
ed
