Im trying to build an HTPC on XBMC LiveCD with no other underlying system (only the LiveCD). I installed the system by selecting option 0 from boot menu which allocated:
2g to /dev/sda1 (/media/sda1)
and
146g to /dev/sda3 (/home)
now when i try to:
# sudo apt-get update
# sudo apt-get upgrade
this gave an error message that "/boot" did not exist
# mkdir /boot
# dpkg --configure -a
#aticonfig --initial --input=/etc/X11/xorg.conf
(which im doing to resolve my ATI Radeon problem and got from this link:
http://forum.xbmc.org/showthread.php?p=2...post252921)
the update line went ok, but when it came to the upgrade, i got this msg:
E: You don't have enough free space in /var/cache/apt/archives/.
my question is, how can i install the system with more space allocated to /dev/sda1 (like 10G or so)?
megacrypto Wrote:Im trying to build an HTPC on XBMC LiveCD with no other underlying system (only the LiveCD). I installed the system by selecting option 0 from boot menu which allocated:
and
now when i try to:
# mkdir /boot
(which im doing to resolve my ATI Radeon problem and got from this link: http://forum.xbmc.org/showthread.php?p=2...post252921)
This might be what you are looking for.
http://forum.xbmc.org/showpost.php?p=262329&postcount=5
rgds,
Dave
Thanks rodercot for your reply, but unfortunatly the only access that I have right now is through putty. My actual problem is:
1. configure my ATI Radeon 9250 graphic card, which requires
2. sudo apt-get update / upgrade, which need
3. space on my sda1
if i can manage to use the space on sda3 to save the updates. This is what i get when I df -h:
Filesystem Size Used Avail Use% Mounted on
unionfs 1.5G 1.5G 0 100% /
varrun 252M 60K 252M 1% /var/run
varlock 252M 0 252M 0% /var/lock
udev 252M 32K 252M 1% /dev
devshm 252M 0 252M 0% /dev/shm
/dev/sda3 146G 188M 138G 1% /home
/dev/sda1 2.0G 1.9G 64M 97% /media/sda1
MPauley73 Wrote:try using parted to resize the partition:
http://www.hermann-uwe.de/blog/resizing-...ith-parted
i doubt that this will work since the partition that i want to resize is the one with the boot on it and in order to resize (from what i understood from the link) is that basically i erease both partitions and then create a new one
This what I got so far:
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "aticonfig-Screen[0]" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "it"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]"
Driver "fglrx"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device "aticonfig-Device[0]"
Monitor "aticonfig-Monitor[0]"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
Option "VideoOverlay" "on"
Option "OpenGLOverlasy" "off"
EndSubSection
EndSection
Still I get the flickering black screen when xbmc trys to start
