Hello!
Is it possible to run XP and XBMC for Windows on a Mac Mini? If so, does XBMC support the Apple Remote when running XBMC for Windows?
Thankful for any help in this matter
Regards
Yes it runs on the MAC Mini but the apple remote isn't supported unfortunately. I didn't got it working with IRSS nor eventghost.
Let me know if it works for you
Hi I am also using XBMC on a Mac Mini running Windows XP SP2, and Apple Remote is not working neither.
Does someone know if there is any way around this, or when will this be supported?
Is there support for the Apple remote by now? I will be installing XBMC v.11 (or 12) on a custom built PC running Windows 7 and have the Apple Universal Dock as a IR-receiver. I'm just wondering if I should bother buying a Apple Remote v.2 or not?
I'm planning on using EventGhost if there's no built in support for this setup by default.
