2009-01-21, 13:16
As you all probably know this warning is on the install tutorial of this site :
On the atvusb-creator site they say :
Are these versions different from the "atvusb-creator-1.0.0.b1.tar.gz"?
In other words, can I install the latest atvusb-creator twice?
Quote:WARNING: DO NOT RUN THE USB PATCHSTICK TWICE, there is an error that will require a Apple TV Factory Restore to fix if you run the PATCHSTICK twice. Much apologies if this has happened and a new version is on its way up. Once again, DO NOT RUN a patchstick made from atvusb-creator-1.0.0.b1.tar.gz TWICE
Quote:Note that the current version is atvusb-creator-1.0.b10 and atv-win-1.0.b11.zip
