Full Version: No sound playing iso files
Hello
A few days i ago i started with XBMC, it works good. Only i dont have sound when playing ISO files. I have been searching on this forum but couldnt get a solotion ( perhaps i didnt searched good enough)
Maybe someone can help me ?
Here is my log
11:50:10 T:1916 M:712687616  NOTICE: Mapping drive Z to C:\Documents and Settings\Chris\Application Data\XBMC\cache
11:50:10 T:1916 M:712654848  NOTICE: Mapping drive T to C:\Documents and Settings\Chris\Application Data\XBMC\userdata
11:50:10 T:1916 M:712654848  NOTICE: Mapping drive Q to C:\Program Files\XBMC
11:50:10 T:1916 M:712654848  NOTICE: Mapping drive U to C:\Program Files\XBMC
11:50:10 T:1916 M:712527872  NOTICE: -----------------------------------------------------------------------
11:50:10 T:1916 M:712515584  NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 2 build 2600.  Built on Nov 13 2008 (compiler 1500)
11:50:10 T:1916 M:712515584  NOTICE: AMD Athlon(tm) XP 2600+
11:50:10 T:1916 M:712515584  NOTICE: Desktop Resolution: 1280x768 32Bit at 60Hz
11:50:10 T:1916 M:712511488  NOTICE: Q is mapped to: C:\Program Files\XBMC
11:50:10 T:1916 M:712511488  NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
11:50:10 T:1916 M:712511488  NOTICE: Log File is located: C:\Documents and Settings\Chris\Application Data\XBMC\xbmc.log
11:50:10 T:1916 M:712511488  NOTICE: -----------------------------------------------------------------------
11:50:10 T:1916 M:712491008  NOTICE: Setup SDL
11:50:10 T:1916 M:711524352  NOTICE: load settings...
11:50:10 T:1916 M:711516160  NOTICE: Mapping drive P to C:\Documents and Settings\Chris\Application Data\XBMC\userdata
11:50:10 T:1916 M:711512064  NOTICE: loading C:\Documents and Settings\Chris\Application Data\XBMC\userdata\guisettings.xml
11:50:10 T:1916 M:711262208  NOTICE: Getting hardware information now...
11:50:10 T:1916 M:711262208  NOTICE: Checking resolution 10
11:50:10 T:1916 M:711262208  NOTICE: Setting autoresolution mode 3
11:50:10 T:1916 M:711254016  NOTICE: No advancedsettings.xml to load (C:\Documents and Settings\Chris\Application Data\XBMC\userdata\advancedsettings.xml)
11:50:10 T:1916 M:711315456  NOTICE: C:\Documents and Settings\Chris\Application Data\XBMC\userdata\sources.xml
11:50:10 T:1916 M:700678144  NOTICE: start dvd mediatype detection
11:50:10 T:1916 M:700665856  NOTICE: initializing playlistplayer
11:50:10 T:1916 M:700661760  NOTICE: DONE initializing playlistplayer
11:50:10 T:1916 M:700649472  NOTICE: load default skin:[PM3.HD]
11:50:10 T:1916 M:696799232  NOTICE: Updating video library on startup
11:50:10 T:1916 M:696836096   ERROR: Control 402 in window 10133 has been asked to focus, but it can't
11:50:10 T:1916 M:696389632  NOTICE: initialize done
11:50:10 T:1916 M:696389632  NOTICE: Running the application...
11:50:10 T:1916 M:695926784  NOTICE: Webserver: Starting...
11:50:10 T:2996 M:695779328  NOTICE: Webserver: Started
11:50:10 T:1916 M:695767040  NOTICE: ES: Starting event server
11:50:10 T:2192 M:694996992  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
11:50:10 T:2192 M:694992896  NOTICE: UDP: Listening on port 9777
11:50:11 T:2916 M:675184640  NOTICE: My Videos: Scanning for video info using worker thread, operation took 00:00
11:50:12 T:1916 M:674054144   ERROR: PICTURE: Error loading image C:\Documents and Settings\Chris\Application Data\XBMC\cache\weather\128x128\.png
11:50:12 T:1916 M:674054144   ERROR: Texture manager unable to load file: C:\Documents and Settings\Chris\Application Data\XBMC\cache\weather\128x128\.png
11:50:14 T:1916 M:690544640 WARNING: CUtil::GetMatchingSource... no matching source found for [Video-plugins]
11:50:19 T:1916 M:672395264  NOTICE: DVDPlayer: Opening: D:\Movies\Defiance (2008).iso
11:50:19 T:1916 M:672391168 WARNING: CDVDMessageQueue::Put MSGQ_NOT_INITIALIZED
11:50:19 T:512 M:672370688  NOTICE: Creating InputStream
11:50:19 T:512 M:671764480  NOTICE: DVDPlayer: playing a dvd with menu's
11:50:19 T:512 M:671756288 WARNING: CDVDInputStreamNavigator::SetNavigatorState - Failed to set state (Virtual DVD machine not started.), retrying after read
11:50:19 T:512 M:671662080  NOTICE: Creating Demuxer
11:50:19 T:512 M:665165824 WARNING: CDVDMessageQueue::Put MSGQ_NOT_INITIALIZED
11:50:19 T:512 M:665063424  NOTICE: Opening Subtitle stream: 1 source: 256
11:50:19 T:512 M:664670208  NOTICE: Opening audio stream: 2 source: 256
11:50:19 T:512 M:664662016  NOTICE: Finding audio codec for: 86020
11:50:19 T:512 M:664535040  NOTICE: Creating audio thread
11:50:19 T:512 M:664403968  NOTICE: Opening video stream: 0 source: 256
11:50:19 T:512 M:664403968  NOTICE: Creating video codec with codec id: 2
11:50:19 T:512 M:664150016  NOTICE: Creating video thread
11:50:19 T:2136 M:664141824  NOTICE: running thread: CDVDPlayerAudio::Process()
11:50:19 T:2136 M:664141824  NOTICE: Creating audio device with codec id: 86020, channels: 2, sample rate: 48000, no pass-through
11:50:19 T:2136 M:663924736 WARNING: CWin32DirectSound::AddPackets - buffer underrun
11:50:19 T:2132 M:659488768  NOTICE: running thread: video_thread
11:50:19 T:2132 M:657514496  NOTICE:  fps: 29.970030, pwidth: 720, pheight: 480, dwidth: 853, dheight: 480
11:50:19 T:2132 M:657506304  NOTICE: Display resolution AUTO : 480p 16:9 (3)
11:50:19 T:2132 M:657502208 WARNING: Upscale: selected algorithm 1
11:50:20 T:1916 M:671285248  NOTICE: GL: Selecting YUV 2 RGB Progressive Shader
11:50:20 T:1916 M:669097984  NOTICE: GL: NPOT textures are supported through GL_ARB_texture_rectangle extension
11:50:30 T:1916 M:646709248  NOTICE: Storing total System Uptime
11:50:30 T:1916 M:646709248  NOTICE: Saving settings
11:50:30 T:1916 M:646668288  NOTICE: stop all
11:50:30 T:1916 M:646668288  NOTICE: Webserver: Stopping...
11:50:30 T:1916 M:646676480  NOTICE: Webserver: Stopped...
11:50:30 T:1916 M:646676480  NOTICE: ES: Stopping event server
11:50:30 T:2192 M:647065600  NOTICE: ES: UDP Event server stopped
11:50:30 T:1916 M:647073792  NOTICE: stop dvd detect media
11:50:30 T:1916 M:647086080  NOTICE: stop player
11:50:30 T:1916 M:647086080  NOTICE: CDVDPlayer::CloseFile()
11:50:30 T:1916 M:647086080  NOTICE: DVDPlayer: waiting for threads to exit
11:50:30 T:512 M:647086080  NOTICE: CDVDPlayer::OnExit()
11:50:30 T:512 M:647086080  NOTICE: DVDPlayer: closing audio stream
11:50:30 T:512 M:647086080  NOTICE: Closing audio stream
11:50:30 T:512 M:647086080  NOTICE: waiting for audio thread to exit
11:50:30 T:2136 M:647086080   ERROR: CDVDAudio::AddPackets - failed to add leftover bytes to render
11:50:30 T:2136 M:647086080  NOTICE: Closing audio device
11:50:30 T:2136 M:647282688  NOTICE: thread end: CDVDPlayerAudio::OnExit()
11:50:30 T:512 M:649412608  NOTICE: Deleting audio codec
11:50:30 T:512 M:649412608  NOTICE: DVDPlayer: closing video stream
11:50:30 T:512 M:649412608  NOTICE: Closing video stream
11:50:30 T:512 M:649412608  NOTICE: waiting for video thread to exit
11:50:30 T:2132 M:649740288  NOTICE: thread end: video_thread
11:50:30 T:512 M:653803520  NOTICE: deleting video codec
11:50:30 T:512 M:655929344  NOTICE: DVDPlayer: closing video stream
11:50:30 T:512 M:655929344  NOTICE: Closing subtitle stream
11:50:30 T:512 M:655929344  NOTICE: CDVDPlayer::OnExit() deleting demuxer
11:50:30 T:512 M:656011264  NOTICE: CDVDPlayer::OnExit() deleting input stream
11:50:30 T:1916 M:656625664  NOTICE: DVDPlayer: finished waiting
11:50:30 T:1916 M:656625664  NOTICE: CDVDPlayerVideo::~CDVDPlayerVideo - uninitting video device
11:50:30 T:1916 M:656629760  NOTICE: stop sap announcement listener
11:50:30 T:1916 M:656629760  NOTICE: clean cached files!
11:50:30 T:1916 M:656621568  NOTICE: unload skin
11:50:30 T:1916 M:673722368  NOTICE: stop python
11:50:30 T:1916 M:673722368  NOTICE: stopped
I dont get much from it, but if someone can tell me, it would be great!
Get a later build (link in my sig.) and try again
P.S.
leuke naam.
dank je Smile
I will try it, butt what is the differents ? Smile
Geitekont Wrote:dank je Smile
have a look on trac and see what has been changed between the official 8.10 release and what the dev's are doing (LOADS....)
It works great Smile only the sound is soft compared to windows media player!
thnx Smile
problem solved Smile
