2009-01-29, 01:07
There is a wiki about setting up Intrepid to be a full XBMC system. The wiki was developed by olympia (the one who made the nVidia guide and wrote most of this guide).
http://wiki.xbmc.org/?title=HOW-TO:_Inst...ep-by-step
Changelog:
27/01/2009
Updated install instructions for flash drives
19/01/2009
ALSA script has been modified to download and install ALSA 1.0.19
18/01/2009
- Change the mode, XBMC starts (from xinit to "startx -- -br"). This way, we avoid the gray dithered window of X. It's now black. Thanks to l.capriotti.
Orginal Guide is here, for the NVIDIA drivers:
http://forum.xbmc.org/showthread.php?tid=44019
This had been modified for the ATi drivers.
Guide Credit gos to olympia.
A guide for installing XBMC on Ubuntu Intrepid Minimal CD version.
Please note:
- I only tested this with ATi
- The guide is for using XBMC on a dedicated HTPC, so there is not any window manager installed
- You need minimum 4GB size flash drive or hard disk to go
This guide walks you through how to install every needed components and XBMC itself, but try to leave to footprint as small as it can.
You will get:
- A dedicated HTPC autoboot to XBMC
- Latest XBMC SVN version
- Upgraded ALSA driver
- Upgraded ATi driver
- Lirc (According to olympia, MS MCE Remote works out of the box, so everybody with other remotes and LCD displays are in his/ her own to solve the individual Lirc issues)
- Suspend/ resume (works perfectly on ASUS P5N7A-VM)
So, let’s start:
FIRST STEP
Download, burn and install Ubuntu Intrepid mini.iso from here:
https://help.ubuntu.com/community/In...tion/MinimalCD
You can also use Intrepid Server Edition from here:
http://www.ubuntu.com/getubuntu/download
Just select Server, pick the mirror closest to you, and then click the download button.
Way use Server over Mini?
I had problems downloading files from the mirrors when installing with the mini. With server, most the files are on the CD. At the boot menu, after you select your language, hit F4 and arrow down to Minimal Install, then hit enter again to start the install. This also works for people will a slow connection.
Apparently there seems to be an issue with Intrepid installer if you are installing to a flash drive. It's not installing GRUB for some reason.
You have to options:
Either install Hardy(Ubuntu 8.04) mini.iso first, which is install GRUB, then right after that, install Intrepid mini.iso over the same flash drive. It will reformat the drive, but GRUB will stay alive on the drive.
Second option is that right after Intrepid mini installation, boot up Intrepid mini.iso from the CD again, choose rescue mode, and there you will find an "install GRUB" option.
During the installation, please set „xbmc” as username and password at the account creation.
At the end, when you have to choose from the optional components, check only „OpenSSH” to be able to access your HTPC remotely via SSH.
After you’re done, boot it up, then use an SSH application (e.g. putty) to log in remotely from your desktop, using the above created username and password. This way, you will be able to copy/ paste all the steps below. Alternatively you can use your console, but then you will have a hard time type in everything.
So once you logged in:
First of all, update the repos, and install all prerequisites using:
NEXT STEP
NEXT STEP
Please note, that as this is a guide for dedicated HTPC and in this case we mostly need passthrough, I choose NOT to install the libs for Pulseaudio and compile XBMC later without Pulseaudio support. As far I understand, only ALSA is needed in this case.
To upgrade ALSA:
I have modified the ALSA upgrade script (available at Ubuntuforums), and now it is working with only “-di” option in our case here (Also on ASUS P5N7A-VM).
To download and use:
NEXT STEP
NEXT STEP
NEXT STEP
This mini version of Intrepid has a bug (or maybe a feature), that the user created at installation is not added to the „audio” group. We need the correct this:
NEXT STEP
or replace „xbmc” with username you installed with
reboot the computer:
NEXT STEP
For some reason, the driver snapshot for ALSA 1.0.19 is not always downloading properly; in this case you have to run the script again. To check whether the driver upgraded or not:
NEXT STEP
If you see driver version 1.0.19 here, you can continue, but if there is 1.0.17 as driver version, then you have to repeat the last 3 STEP (upgrade, reboot, check).
If it’s OK, then you can delete the just downloaded ALSA source to free up some disk space:
NEXT STEP
Now run alsamixer:
NEXT STEP
Navigate right with cursor keys until IEC958 and unmute all three of them (IEC958) with „M” key. You should see in case of all three IEC958 a „00” in green background. Press „ESC” to quit from alsamixer.
Now, you have to edit the following file, using nano for example:
NEXT STEP
and add this line to the end:
To update ATi driver
To start off, there are some necessary programs you need.
NEXT STEP
Now to get the run file. This is for both x86 and 64-bit systems.
NEXT STEP
NEXT STEP
(NOTE: if you are using Hardy, then switch intrepid to hardy)
Once the deb files are made, you need to install them.
32-BIT SYSTEMS
Skip to ,,install XBMC'' if you install the 32-bit edtion.
64-BIT SYSTEMS
The above dpkg command (64-bit only) may complain that "Errors were encountered while processing: fglrx-amdcccle". This is because of a dependency of the amdccle package on 32 bit libraries. If you receive this error, issue the following command after the above dpkg command, which will force the installation of all of the 32 bit dependencies, and then the amdcccle package.
FIX 64-BIT
The 64-bit systems requires the --force-overwrite command in the above dpkg command
Now you can delete ATi installer and deb files.
NEXT STEP
To install XBMC (latest SVN)
NEXT STEP
Wait for downloading XBMC source files, might takes long time, depend on your Internet connection. After it downloaded:
NEXT STEP
OPTIONAL STEP
If you experience problems with Intrepid ffmpeg performance (most probably you will) which is under discussion here: http://forum.xbmc.org/showthread.php?tid=43075, you may want to try aron's patch (thank you aron, for this).
Please be aware, that this is not supported and not recommended by team-XBMC. If you don't want to install this patch, just skip all the optional steps and jump to the closest "NEXT STEP".
OPTIONAL STEP2
OPTIONAL STEP3
Then configure/compile/install XBMC:
NEXT STEP
NEXT STEP
(NOTE: use only „make”, if you don’t have a dualcore CPU)
This is again, can take a a while, depend on your CPU speed.
NEXT STEP
Changelog:
27/01/2009
19/01/2009
18/01/2009
Please note:
You will get:
So, let’s start:
FIRST STEP
NEXT STEP
#sudo apt-get update
NEXT STEP
#sudo apt-get install –y subversion make g++ gcc gawk pmount libtool nasm automake cmake gperf unzip bison libsdl1.2-dev libsdl-image1.2-dev libsdl-gfx1.2-dev libsdl-mixer1.2-dev libsdl-sound1.2-dev libsdl-stretch-dev libfribidi-dev liblzo-dev libfreetype6-dev libsqlite3-dev libogg-dev libasound-dev python-sqlite libglew-dev libcurl4-gnutls-dev x11proto-xinerama-dev libxinerama-dev libxrandr-dev libxrender-dev libmad0-dev libtre-dev libogg-dev libvorbis-dev libmysqlclient-dev libpcre3-dev libdbus-1-dev libhal-dev libhal-storage-dev libjasper-dev libfontconfig-dev libbz2-dev libboost-dev libfaac-dev libenca-dev libxt-dev libxmu-dev libpng-dev libjpeg-dev wget build-essential linux-headers-`uname -r` xorg pm-utils mingetty
To upgrade ALSA:
NEXT STEP
#wget http://217.20.138.65/AlsaUpgrade-1.0.x-rev-1.15-Ben.sh
NEXT STEP
#chmod 777 AlsaUpgrade-1.0.x-rev-1.15-Ben.sh
NEXT STEP
#sudo ./AlsaUpgrade-1.0.x-rev-1.15-Ben.sh -di
NEXT STEP
#sudo usermod -a -G audio xbmc
NEXT STEP
#sudo reboot
NEXT STEP
#more /proc/asound/version
NEXT STEP
#sudo rm -r /usr/src/Alsa-1.0.19/
Now run alsamixer:
NEXT STEP
#alsamixer
NEXT STEP
#sudo nano /etc/modprobe.d/alsa-base
#options snd-hda-intel model=6stack-dig
NEXT STEP
#sudo apt-get install -y build-essential cdbs fakeroot dh-make debhelper debconf libstdc++5 dkms
NEXT STEP
#wget http://www2.ati.com/drivers/linux/ati-driver-installer-8-12-x86.x86_64.run
NEXT STEP
#sudo sh ati-driver-installer-8-12-x86.x86_64.run --buildpkg Ubuntu/intrepid
32-BIT SYSTEMS
#sudo dpkg -i xorg-driver-fglrx_8.561-0ubuntu1_i386.deb fglrx-kernel-source_8.561-0ubuntu1_i386.deb fglrx-amdcccle_8.561-0ubuntu1_i386.deb
64-BIT SYSTEMS
#sudo dpkg -i xorg-driver-fglrx_8.561-0ubuntu1_amd64.deb fglrx-kernel-source_8.561-0ubuntu1_amd64.deb fglrx-amdcccle_8.561-0ubuntu1_amd64.deb
FIX 64-BIT
#sudo apt-get install -f
#sudo dpkg -i --force-overwrite xorg-driver-fglrx_8.561-0ubuntu1_amd64.deb fglrx-kernel-source_8.561-0ubuntu1_amd64.deb fglrx-amdcccle_8.561-0ubuntu1_amd64.deb
NEXT STEP
#rm ati-driver-installer-8-12-x86.x86_64.run *.deb
NEXT STEP
#svn checkout https://xbmc.svn.sourceforge.net/svnroot/xbmc/branches/linuxport/XBMC
NEXT STEP
#cd XBMC
OPTIONAL STEP
OPTIONAL STEP2
#wget http://trac.xbmc.org/raw-attachment/ticket/5680/xbmc_ffmpeg_mt.patch
OPTIONAL STEP3
#patch -p0 < xbmc_ffmpeg_mt.patch
NEXT STEP
#./configure --prefix=/usr --disable-pulse
NEXT STEP
#make -j2
NEXT STEP
#sudo make install
