Full Version: Issue with Fan art
Hi guys,
I seem to be having an issue with fan art being scraped correctly.
I completely removed xbmc and the userdata and install a new rev (svn17432)
and tried rescraping my movie library. I also had the issue with 8.10 so thought I should try a newer svn.
The first 5 or so movies scraped properly from the nfo files (both poster and fanart), but after that I start to see this appear in the log :
22:10:39 T:1432 M:587456512 DEBUG: Found matching nfo file: Y:\A Nightmare On Elm Street - 7 - Wes Craven's New Nightmare.nfo
22:10:39 T:1432 M:587194368 DEBUG: VIDEO::CVideoInfoScanner::CheckForNFOFile Got details from nfo
22:10:39 T:1432 M:587247616 DEBUG: Adding new item to movies:Y:\A Nightmare On Elm Street - 7 - Wes Craven's New Nightmare.avi
22:10:49 T:1432 M:587587584 DEBUG: CVideoDatabase::GetMovieId (Y:\A Nightmare On Elm Street - 7 - Wes Craven's New Nightmare.avi), query = select idMovie from movie where idFile=41
22:10:49 T:1432 M:587575296 DEBUG: CVideoDatabase::GetMovieId (Y:\A Nightmare On Elm Street - 7 - Wes Craven's New Nightmare.avi), query = select idMovie from movie where idFile=41
22:10:59 T:1432 M:587522048 INFO: Caching image from: Y:\A Nightmare On Elm Street - 7 - Wes Craven's New Nightmare-fanart.jpg to C:\Documents and Settings\User\Application Data\XBMC\userdata\Thumbnails\Video\Fanart\57ff3ce5.tbn
22:10:59 T:1432 M:587505664 ERROR: XFILE::CFile:Big Grinelete - Error deleting file C:\Documents and Settings\User\Application Data\XBMC\userdata\Thumbnails\Video\Fanart\57ff3ce5.tbn
I used media companion to create the nfos and to scrape the poster and fanart so they are using the right format.
The posters all appear correctly, its just the fan art tat isn't working.
Anyone else run into this? I also find that when I exit or enter library mode, xbmc seems to "freeze" for about 10 - 20 seconds before it changes screens.
Could this be a memory issue on the PC as I only have 1gig of ram
Let me know if you need a pastebin of the full log as I have asked about 2 things Smile
Thanks in advance.
57ff3ce 5.tbn doesn't look right with that space in there but I could be wrong.
EDIT: Just had a look at my fanart thumbs and none of them have spaces in the name so I think that is the problem.
Did you delete the USERDATA folder found in C:\Documents and Settings\User\Application Data\XBMC\ ?
yes I deleted that directory, but I'll try again.
Strange thing is the movies with working fan art don't even show trying to cache the fan art locally...
At work right now so will try tonight.
