I use "black" as screen saver, and when a movie is paused its dimmed pretty much.
Every 5 min or so, the screen flash. Like if the screensaver goes of and then on again.
Someone with the same problem....?
I hoped it doesnt have to do with the droppes I get ever now and then in the movies...?
g780 and a 4850 is what I got,....
/Söder
It's gnome/k/x screensaver trying to activate. The dbus-send command we try to send in the launcher script is completely unreliable. If you manually inhibit the screensaver (gnome even has a toolbar plugin for this) the flash should go away.
althekiller Wrote:It's gnome/k/x screensaver trying to activate. The dbus-send command we try to send in the launcher script is completely unreliable. If you manually inhibit the screensaver (gnome even has a toolbar plugin for this) the flash should go away.
Ok, any way you can describe how to do it? It is the same as inactivate the screen saver in Ubuntu?
/Söder
soder Wrote:Ok, any way you can describe how to do it? It is the same as inactivate the screen saver in Ubuntu?
/Söder
Yup, somewere in screen settings IIRC
Topfs2 Wrote:Yup, somewere in screen settings IIRC
Like "screensaver" and unmark "activate screensaver when idle"?
And never put the screen to sleep?
/Söder
It worked I think. Thanks.
/Söder
Wow, thanks! This has been bugging me FOREVER but I never mentioned it as it seemed a minor annoyance in the grand scheme. Will try this fix ASAP - appreciate it!
Superb - I thought this was either my GFX card or Screen on their way out on one of my machines - had been worrying me for ages!
Stumbled accross this thread and voila! Problem solved
