Full Version: myth:// URL not working in r17515
I've just updated XBMC to the latest svn. The Myth TV integration doesn't seem to want to work anymore.
There seem to have been some URL handling changes after looking at the svn log. Not sure if this might have something to do with it. There's an error message about a DLL not being loaded as well.
All I get when I choose my Myth TV source is a box popping up that says:
Quote:Remote Share
Could not connect to network server.
A short snippet from the XBMC log is below. Full log at http://pastebin.com/m53b8aba2
Quote:23:55:36 T:3065763632 M:777576448 DEBUG: Clearing cached fileitems [myth://192.168.1.3/]
23:55:36 T:3065763632 M:777576448 DEBUG: CGUIMediaWindow::GetDirectory (myth://192.168.1.3/)
23:55:36 T:3065763632 M:777576448 DEBUG: ParentPath = []
23:55:36 T:3065763632 M:777576448 DEBUG: SECTION:LoadDLL(xbmc.so)
23:55:36 T:3065763632 M:777576448 DEBUG: Dll xbmc.so was not found in path
23:55:36 T:3065763632 M:777576448 ERROR: GetDirectory - Error getting myth://192.168.1.3/
23:55:36 T:3065763632 M:777576448 ERROR: CGUIMediaWindow::GetDirectory(myth://192.168.1.3/) failed
23:55:36 T:3065763632 M:777576448 DEBUG: CGUIMediaWindow::GetDirectory ()
23:55:36 T:3065763632 M:777576448 DEBUG: Sort, sorting took 0 millis
Is anyone else having problems with Myth TV integration with a late revision?
I've done a complete uninstall, complete distclean, re-configure and make and reinstall just to check something dodgy didn't happen with the install. Still same problem though.
Same SVN revision, same problem, same error.
Myth version is 0.21
Myth TV is not working in the update I got tonight either (r17535). Do I need to create a Trac ticket?
I spent a while fixing up a bunch of merges from my recent update, and I can't simply go back to the previous build that was working for me as the DVD stuff was broken and now that's important to have working for WAF.
So close to a stable system that I hopefully won't need to update in a while...
something have broken loading of the xbmc binaries symbols.
fixed in svn r17542
Legend. Thanks so much. WAF restored and with the new ATI drivers I finally get smooth 1080i playback for our recorded digital terrestrial TV. Awesome!
