2009-02-02, 02:15
Maybe this is something very simple that i am overlooking, but, I just installed XBMC on my iMac, and, I am LOVING it so far.
however, every time that i calibrate my screen to fit the entire XBMC screen, and, then exit XBMC and go back in, I have to keep re-calibrating it to fit once again. It is like I never even changed any settings.
1 more thing, I enter my username and password for 1 of my SMB windows shares, and, if I exit out of XBMC and go back in, I have to enter my credentials to get to the share again (Which can be very annoying if I am on the couch using my remote.
It is almost as if XBMC isn't holding my settings. Doe this make sense?
Thank you in advance for any help.
Gary
Gary
