Full Version: AC3 passhtru is always delayed
Intrepid 8.10.
This happens no matter file I open with AC3. Sound is always delayed by ~200ms.
I use optical on my Gigabyte GA-73PVM-S2H.
aplay -L output:
CARD=NVidia
    HDA NVidia, ALC885 Analog
    Default Audio Device
front:CARD=NVidia,DEV=0
    Front speakers
surround40:CARD=NVidia,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=NVidia,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=NVidia,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=NVidia,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=NVidia,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=NVidia,DEV=0
    HDA NVidia, ALC885 Digital
    IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=NVidia,DEV=0
    HDA NVidia
    HDMI Audio Output
null
    Discard all samples (playback) or generate zero samples (capture)
default:CARD=CX8811
    Conexant CX8811, CX88 Digital
XBMC Audio Hardware Config:
Audio output -> digital
Dolby Digital AC3 capable -> on
DTS -> on
Audio output device -> iec958
Passthrough output device -> iec958
Videos just outputting stereo play back fine.
Thanks in advance Smile It is really bugging me since I have to adjust audio offset for every episode in ac3 I see. And there's a lot of them.
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 41mn 46s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Sampling rate : 48.0 KHz
