Full Version: System volume OSD
Is it possible to get the OSD volume display to show on system volume change?
The reason i ask is that I don’t use the inbuilt volume handler (+ and -) in XBMC, instead I use the system volume. This is because I use my HTPC with other applications such as WMV for live-tv for instance. The problem is that if I change the volume in WMC it doesn’t affect the volume level in XBMC and vice versa, so if the system volume is on low level after watching TV and I start XBMC I cannot increase the volume in XBMC enough. But at the same time I miss the visual feedback from the OSD.
