I read it is possible to activate USB external disk with XMBC. I also installed NitoTV. I cannot see any way to do that.
What are the steps to accomplish this ?
Additional question : once the disk is connected to the ATV, is it possible to remotely access it from a computer ?
Thank you so much or your help,
Ronan
Don't now if you use window or mac. (I'am on windows, drive has to be formated in fat32)
But here's a begining:
Download Mac OS X 10.4.9
link:
http://support.apple.com/downloads/Mac_O...te__Intel_
Install:
You need a program like winspc (
http://winscp.net/download/winscp417setup.exe )or filezilla de(
http://filezilla-project.org/) to place the macOSXUpdCombo10.4.9Intel.dmg file in the right place on your apple tv
open the program on your pc choose session
loggin to your apple tv
adress is ip adres of your appletv (you can find it on your apple tv under general info) fill in adress without DHCP before it
user name: frontrow
password: frontrow
copy the macOSXUpdCombo10.4.9Intel.dmg into the... frontrow\Documents Foler (Create Documents folder if it's not there)
exit program
No go to to your television and your apple tv choose nito tv
Choose settings then instal software then smart installer.
Rember don't connect anything in to the usb port
Atv is starting to update "thinking" wait till its completed
Best is to shutdown and restart the apple tv
Rember; don't start atv with a usb drive or stick connected (won't boot)
When you are in the main screen of atv. you can plug in a drive (some drive's even small one's need external power)
Give it some time to read
Start XBMC
Your new drive must know be visible under Volumes.
let me no if it works for you
good luck
once you have usb enabled you should be able to have the usb drive plugged in while the appletv boots up unless you've formatted it as a boot disk? format the drive as fat32 or hfs+ for better results. it may not read ntfs.
It seems that I already have the dmg file on my ATV ; I guess it was installed automatically either by my USB-creator patchstick, either by the NITO plugin and its extension.
Anyway, my USB disk is a Mac OS extented format ; would this be recognized by the ATV ?
I did not have the answer to my 2nd question: is it possible to have the ATV share the disk on the network ? I don't want to need to plug/unplug the disk all the time.
If not possible, I might buy a dédicated NAS...
Thank you for your help.
Ronan
Hi, i am using the atv 2.3. I did everything and installed NitoTV and copied the Mac Os 10.4.9 file into documents in the apple tv but when i install smart installer it fails to install. Any ideas what i am doing wrong ?
hafidhk Wrote:Hi, i am using the atv 2.3. I did everything and installed NitoTV and copied the Mac Os 10.4.9 file into documents in the apple tv but when i install smart installer it fails to install. Any ideas what i am doing wrong ?
The smart installer in NitoTV reports a log of what it did, you could start by looking at that for errors.
HI guys,
how long should I wait? the ATV has been "Thinking" for about 50 min. now?
Should it take so long?
greets
Dacade
never mind...
iff I lett the smartinstaller download the combo file it doesnt really work. Iff I manualy copy the combo file over to the @tv then the Smartinstaller is finisched in 10 seconds..
Dont know why?! but Im up and running now..
