2009-02-07, 23:10
2009-02-07, 23:47
For me, the same thing happens as in the "Apple Movie Trailers II" plguin, nothing happens...
I just installed it from the SVN and when I try to launch it, the window that tries to load the items from the web, quickly appears and disappears and from what I can see, it doesn't retrieve any items, it says 0.
2009-02-07, 23:49
then pastebin a full debug log. can't help without your help
2009-02-07, 23:56
For a full debug log, I need to enable it in the advancedsettings.xml right? And which one is the log? Some file specifically or the one in my profile folder (since I use 8.10 Atlantis with -p flag) named xbmc.log?
2009-02-07, 23:57
Manual has all this information. You can also look at the links in my signature.
2009-02-07, 23:59
Same here.
(Hope I got all of the relevant stuff)
22:53:41 T:3066890032 M:275951616 INFO: initializing python engine.
22:53:41 T:3066890032 M:275951616 DEBUG: Loading: /usr/share/xbmc/system/python/python24-i486-linux.so
22:53:42 T:3066890032 M:275759104 DEBUG: new python thread created. id=2
22:53:42 T:2845805456 M:275759104 DEBUG: Running thread 2845805456
22:53:42 T:2845805456 M:275759104 DEBUG: thread start, auto delete: 0
22:53:42 T:2845805456 M:275759104 DEBUG: Python thread: start processing
22:53:42 T:3066890032 M:275689472 DEBUG: WaitOnScriptResult - waiting on the Youtube plugin...
22:53:42 T:2845805456 M:275689472 NOTICE: -->Python Interpreter Initialized<--
22:53:42 T:2845805456 M:275689472 NOTICE: Traceback (most recent call last):
22:53:42 T:2845805456 M:275689472 NOTICE: File "/home/eee/.xbmc/plugins/video/Youtube/default.py", line 33, in ?
22:53:42 T:2845805456 M:275689472 NOTICE: plugin.Main()
22:53:42 T:2845805456 M:275689472 NOTICE: File "/home/eee/.xbmc/plugins/video/Youtube/YoutubeAPI/xbmcplugin_categories.py", line 26, in __init__
22:53:42 T:2845805456 M:275689472 NOTICE: self.make_presets_folders()
22:53:42 T:2845805456 M:275619840 NOTICE: File "/home/eee/.xbmc/plugins/video/Youtube/YoutubeAPI/xbmcplugin_categories.py", line 38, in make_presets_folders
22:53:42 T:2845805456 M:275619840 NOTICE: os.makedirs( xbmc.translatePath( self.BASE_PRESETS_PATH ) )
22:53:42 T:2845805456 M:275619840 NOTICE: File "/usr/share/xbmc/system/python/python24.zip/os.py", line 159, in makedirs
22:53:42 T:2845805456 M:275619840 NOTICE: mkdir(name, mode)
22:53:42 T:2845805456 M:275619840 NOTICE: OSError
22:53:42 T:2845805456 M:275619840 NOTICE: :
22:53:42 T:2845805456 M:275619840 NOTICE: [Errno 2] No such file or directory: 'special://profile/plugin_data/video/Youtube'
22:53:42 T:2845805456 M:275619840 ERROR: Scriptresult: Error
22:53:43 T:2845805456 M:275554304 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/time.so. flags: 2
22:53:43 T:2845805456 M:275415040 DEBUG: Loading: /tmp/xbmc-eee/time.so
22:53:43 T:2845805456 M:275415040 DEBUG: RegisterExtensionLib, adding Z:/time.so (0xac00a0c8)
22:53:43 T:2845805456 M:275415040 DEBUG: xbp_dlsym - load symbol inittime
22:53:43 T:2845805456 M:275496960 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/collections.so. flags: 2
22:53:43 T:2845805456 M:275496960 DEBUG: Loading: /tmp/xbmc-eee/collections.so
22:53:43 T:2845805456 M:275496960 DEBUG: RegisterExtensionLib, adding Z:/collections.so (0xb06e2310)
22:53:43 T:2845805456 M:275496960 DEBUG: xbp_dlsym - load symbol initcollections
22:53:43 T:2845805456 M:275496960 INFO: Python script stopped
2009-02-07, 23:59
i should say you need a very recent xbmc build. after the special:// paths patch. and until that patch is merged back to xbox branch. it won't work on xbox.
2009-02-08, 00:01
all but the build date and revision.
2009-02-08, 00:07
Arr. Here you are:
22:53:08 T:3066890032 M:306335744 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Nov 14 2008 (SVN:16164)
It's the plain old Atlantis release.
2009-02-08, 00:09
You need to update.
2009-02-08, 00:12
I guess I have too...
Couple of questions though, after upgrading to the latest SVN, should we reinstall the plugins too from the SVN Repo Installer?
And another thing, are they still going to the XBMC folder in "Program Files" (in Windows case) or to the user folder?
2009-02-08, 00:28
Good advise, tslayer.
Works now like a charm... thank you both!
2009-02-09, 13:50
there is small bug.
before you could use plugin, you must run settings and set download path.
this causes problem
<setting id="download_path" type="folder" source="video" option="writeable" label="30110" default="" />
this causes problem
2009-02-16, 20:06
Hi Nuka1195,
Great plugin, thanks a lot.
I got the last release from SVN (last commit from Feb 9th), it works on windows, but it doesn't works on last official release of XBMC on XBOX and on Mac.
I made a quick fix in the xbmcplugin_category.py file which cover all the cases (tested on Windows, XBOX and Mac).
No changes after 'def __init__( self )'
As you can see the issue is on special path still not recognized properly on XBOX and Mac. The test on mac is done because it seems there is a pb when you check is the directory exists, whatever, just to let know this works.
I made available your plugin with this fix via the script Installer Passion-XBMC
Thank again
Category module: list of categories to use as folders
# main imports
import sys
import os
import xbmc
import xbmcgui
import xbmcplugin
PLATFORM_MAC = os.environ.get( "OS", "" ).lower() == "os x"
class _Info:
def __init__( self, *args, **kwargs ):
self.__dict__.update( kwargs )
class Main:
# base paths
BASE_SKIN_THUMBNAIL_PATH = "/".join( [ "special://xbmc", "skin", xbmc.getSkinDir(), "media", sys.modules[ "__main__" ].__plugin__ ] )
if PLATFORM_MAC or not os.path.isdir( BASE_SKIN_THUMBNAIL_PATH ): BASE_SKIN_THUMBNAIL_PATH = "/".join( [ "Q:\\", "skin", xbmc.getSkinDir(), "media", sys.modules[ "__main__" ].__plugin__ ] )
BASE_PLUGIN_THUMBNAIL_PATH = os.path.join( os.getcwd(), "thumbnails" )
BASE_PRESETS_PATH = "/".join( [ "special://profile", "plugin_data", "video", os.path.basename( os.getcwd().replace( ";", "" ) ) ] )
if PLATFORM_MAC or not os.path.isdir( BASE_PRESETS_PATH ): BASE_PRESETS_PATH = "/".join( [ "P:\\", "plugin_data", "video", os.path.basename( os.getcwd().replace( ";", "" ) ) ] )
def __init__( self ):
Thank again
2009-03-02, 05:42
You may now play those adult rated videos, requires you supply a username/password for logging in.
Quote:
[Youtube]
-changed: version -> 1.2
-added: login with cookie. needed for those adult videos. why the api authentication isn't enough is beyond me.
Quote:
[Youtube]
-changed: version -> 1.1
-changed: english language strings
-added: authentication
-changed: save presets in users settings.xml file
-changed: use xbmc.skinHasImage() check for category icons. (They need to be in skinname/media/Youtube/, named identical to the method name with a .png ext. eg "recently_featured.png")
