Pages: 1 2 3 4 5 6 7 8 9 10 11
You did not oversee it, as of currently there's is no way to utilize TV Show Genre Posters.. although digitalhigh might have incorporated it in Serenity, you would have to check with him.. CF2009 did an excellent mod for Aeon for the Movie Genre Posters, and with luck he might do the same for TV Shows.. no promises though..
ah, okay, thank you very much for the quick answer...:-D
JoWa
if you are using the mod pack for aeon, then as of right now there is no supporn for a seperate tv genre posters, i will look in to adding it to the mod pack but it will not be unto next week.
but i am happy for anyone to mod it all you need to do is copy the
Includes_moviegenre.xml and rename it to
Includes_tvgenre.xml then edit it to only be visible for the tv library then add some visible tags to all the views oh and edit
Includes_moviegenre.xml so it's not visible in tv library...
it is easy but it's just alot of time todo
asphinx
damn you
can i put in a order for tv ones that match the movie ones...
Of course you can, though personally I would prefer it that Movies and TV Shows are easily distinguishable from each other regardless of whether your inside a specific category.. Are they're others who would prefer to have TV Shows in Vivid Silver as well as opposed to Vivid Rust?
(Yeah I have an passion for naming things all over the place..)
CF2009 Wrote:@JoWa
but i am happy for anyone to mod it all you need to do is copy the Includes_moviegenre.xml and rename it to Includes_tvgenre.xml then edit it to only be visible for the tv library then add some visible tags to all the views oh and edit Includes_moviegenre.xml so it's not visible in tv library...
will take a look at it...
btw.: supporn? freudian slip?
I for one, like the idea of TV Shows in Vivid Rust and Movies in Vivid Silver
Hey these are absolutely AWESOME, i'm sure you've gotten this a hundred times, but any word when the Colored ones are coming out, they look Totally sweet!
Thanks,
--FF
The plan is to start working on the coloured ones after I feel that Movie & TV Genre Posters are "a complete set" so to speak.. Which looks to be soon, unless there's a genre somewhere which I have missed..
Is there a reason that the tv show icons were made with a brown texture to them instead of the gray that has been used with the movies. It doeesn't look the best because it is not consistent in the skin.
ekim232 Wrote:Is there a reason that the tv show icons were made with a brown texture to them instead of the gray that has been used with the movies. It doeesn't look the best because it is not consistent in the skin.
The answer is a few posts above...
--> ekim232, just like Nazgulled said the answer to that question is in post #94. But in the spirit of user-flexibility I am considering making the Packs interchangeable, meaning that I might make TV Shows in Vivid Silver and Movies in Vivid Rust, so people can choose whichever they prefer. No promises though as I haven't decided yet.
On a sidenote thougt I would very much like to know if there's any genres that I've missed? I wanna be sure before I start making the coloured ones..
digitalhigh, asphinx
These color genre posters are really, really looks awesome!
From genre point of view, I only miss one at the moment: travel
Would be great, if you could able to make it.
Also, Would be great to have posters from that kind for:
- DVD movies
- HD movies
- DVDrip movies
Thank you in advance for have a look on these.
Hmm.. Travel would be a custom genre, but I'll think about it.. As for the source posters idea you have, their not feasable in the Silhouettes Posters.. but that's doesn't mean I couldn't make them anyway, just not as a part of the Silhouettes..
asphinx Wrote:Hmm.. Travel would be a custom genre, but I'll think about it.. As for the source posters idea you have, their not feasable in the Silhouettes Posters.. but that's doesn't mean I couldn't make them anyway, just not as a part of the Silhouettes..
Actually I am not speaking about Silhouettes but these ones (as I tried to referred by color posters
From the OP:
"UPDATE 24.03 | 42 Posters for you to enjoy!
Movie Genre Posters available. A collaboration between myself and digitalhigh. It's my original Movie Genre Posters, but expanded to 42 Posters courtesy of digitalhigh. You'll find them in the usual place, and for those that have no idea where that is just look in "Fd PRESENTS" and Game Posters."
Oh those.. I must've missed the "colour posters" -part.. My bad..
Well for those I see no problem in making all sorts of genres as the visual guideline is not as strict.. ergo, there isn't one..
Did you notice that a PSD template is freely available for anyone interested in making/modifying their own..
