Full Version: Crashing Again
Getting crashes again, Looks like its related to weather again.
02:43:56 T:2684407808 M: 37601280 ERROR: Window Translator: Can't find window settingscategory
02:43:56 T:2684407808 M: 37617664 ERROR: Error evaluating boolean expression !Window.Previous(0) + !Window.Previous(SettingsCategory) + !Window.Previous(1001) + !Window.Previous(130) + !Window.Previous(34)
02:43:56 T:43351040 M: 37560320 NOTICE: HTTP: connect failed: Permission denied
02:43:56 T:43351040 M: 37572608 ERROR: Unable to connect to xoap.weather.com: 13
02:43:56 T:43351040 M: 37572608 ERROR: WEATHER: Weather download failed!
I removed the weather from guisettings.xml but i cant seem to get it to work, how do i properly remove or comment out the weather?
<weather>
<areacode1>USNY0996 - New York, NY</areacode1>
<areacode2>UKXX0085 - London, United Kingdom</areacode2>
<areacode3>JAXX0085 - Tokyo, Japan</areacode3>
<jumptolocale></jumptolocale>
<sep1></sep1>
</weather>
There's no crash there. Post the entire log on pastebin.com
xbmc log is http://pastebin.ca/1336799
And CrashReporter is http://pastebin.ca/1336824
unplugging the network does nothing btw. xbmc will sit at the xbmc window and stays there or i get error 5.
Crash reporter doesn't tell me much unfortunately, but the log indicates you are having network connectivity issues which may or may not be related.
Enabling debug logging (via advancedsettings.xml) might give you some more information to go on.
Cheers,
Jonathan
How do i enable it without getting into xbmc?
I grabbed the advancedsettings.xml from the userdata folder and all thats in there is
<advancedsettings><skiploopfilter>48</skiploopfilter></advancedsettings>
Just an additional note, I dont think xbmc is technically crashing.
All i get is the xbmc logo and thats all.
I think it's <loglevel>2</loglevel> that you need to add (inside the <advancedsettings> tag ofcourse).
The online manual on advancedsettings.xml will have some more details.
Cheers,
Jonathan
I needed to get running again the next day so i removed the userdata folder and let xbmc recreate it.
I have had no problems since (keeping fingers crossed)
I will let you know if i see any more issues
