default.py:
line 170 and 177
www.toonsurfer.110mb.com to toonsurfer.50webs.com
also "Default.tbn.jpg" filename to "default.tbn"
Best regarts,
Ö.B.
thanks for that, fixed in SVN
queeup Wrote:default.py:
line 170 and 177
http://www.toonsurfer.110mb.com to toonsurfer.50webs.com
Best regarts,
Ö.B.
Does this still work for you?
I am getting an error when trying to use this plugin...
I am new to all of this, and JUST got XBMC working on my XBox...
klockk Wrote:Does this still work for you?
I guess I was wrong... it works on some items, and not others....
That must be an indication that the source file doesn't exist on the remote server...??
This plugin has been updated to show all of the episodes, the previous version stopped at season 6. I do not intend to maintain this plugin really, if someone is interested let me know, or if someone can merge this into the svn that would be great. Im not at all sure how to move to the new addon system, again if someone was interested that would be great. The file can be found at
http://rapidshare.com/files/401113530/My...pdated.zip
How do i install this in Dharma on Win 7 64 bit ?
Pointing to the zip file does nothing.
Or is this part of some repository, if so which ?
Thanks for any replies
