Full Version: No sound and really fast playback of video in XBMC in Ubuntu 8.04
I think this is eveything anyone would need to know about my hardware setup. Sound is working perfectly in all other apps that I am aware of - Songbird, MoviePlayer, Amarok, etc., but not XBMCSad
sparkie@UbuntuHolmwood:~$ lsusb
Bus 005 Device 004: ID 0424:2514 Standard Microsystems Corp.
Bus 005 Device 003: ID 05a9:2643 OmniVision Technologies, Inc.
Bus 005 Device 002: ID 0424:2512 Standard Microsystems Corp.
Bus 005 Device 001: ID 0000:0000
Bus 004 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
sparkie@UbuntuHolmwood:~$ lspci
00:00.0 Host bridge: Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
00:01.0 PCI bridge: Intel Corporation 82865G/PE/P PCI to AGP Controller (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev c2)
00:1f.0 ISA bridge: Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801EB/ER (ICH5/ICH5R) IDE Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801EB (ICH5) SATA Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller (rev 02)
00:1f.5 Multimedia audio controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev 02)
01:00.0 VGA compatible controller: nVidia Corporation NV44A [GeForce 6200] (rev a1)
02:03.0 Ethernet controller: 3Com Corporation 3c905C-TX/TX-M [Tornado] (rev 78)
sparkie@UbuntuHolmwood:~$ cat /proc/asound/cards
0 [ICH5 ]: ICH4 - Intel ICH5
Intel ICH5 with AD1985 at irq 20
1 [SP2208WFP ]: USB-Audio - Monitor Webcam (SP2208WFP)
Mic-OmniVision Technologies, Inc.538-2640-07.08.09.6 Monitor Webcam (SP2208WFP)
sparkie@UbuntuHolmwood:~$ cat /proc/asound/modules
0 snd_intel8x0
1 snd_usb_audio
sparkie@UbuntuHolmwood:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ICH5 [Intel ICH5], device 0: Intel ICH [Intel ICH5]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: ICH5 [Intel ICH5], device 4: Intel ICH - IEC958 [Intel ICH5 - IEC958]
Subdevices: 1/1
I have been working on trying to fix this for months and have almost given up. Any help would be greatly appreciated. XBMC works flawlessly on my iMac.
PS Webcam doesn't work either, but that is a different issue (I think).
Stare Doesn't anyone know how to use the search function anymore?!?
This is a VERY common problem and you can EASILY find the solution if you search. There's a also a sticky about posting your problems in a useful manner.
EDIT - Here's some help...
The video/sound issue is due to PulseAudio. Seach on how to disable it when launching XBMC.
Posting about problems
Aenima99x Wrote:Stare Doesn't anyone know how to use the search function anymore?!?
Dude, do you not think I've been combing through search for months on this. Generally 'Search' utilities suck in forums. "Really fast video" doesn't return much of anything useful and "no sound" returns dozens of hits - most of which do not apply to my situation it seems. Unless one knows the solution (i.e. PulseAudio - thanks by the way), already, it can sometimes be difficult to find hits that can address the right problem.
As far as your PulseAudio suggestion goes - no go. May be a well documented problem, but not my problem it seems. XBMC is the only app I cannot get to work properly with sound, so that's why I'm pleaing for help here. One posting did have good information on fixing some PulseAudio bugs in Ubuntu 8.04 and suggested posting the following information:
Subdevices: 1/1
Subdevices: 1/1
sparkie@UbuntuHolmwood:~$ pkill pulseaudio; sleep 2; pulseaudio -vv
I: main.c: Called SUID root and real-time/high-priority scheduling was requested in the configuration. However, we lack the necessary priviliges:
I: main.c: We are not in group 'pulse-rt' and PolicyKit refuse to grant us priviliges. Dropping SUID again.
I: main.c: For enabling real-time scheduling please acquire the appropriate PolicyKit priviliges, or become a member of 'pulse-rt', or increase the RLIMIT_NICE/RLIMIT_RTPRIO resource limits for this user.
I: main.c: Note that real-time/high-priority scheduling is NOT normally required. If you experience crackling or other sound anomalies, consider one or more of the above solutions.
I: main.c: High-priority scheduling enabled in configuration but now allowed by policy. Disabling forcibly.
W: main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Operation not permitted
W: main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Operation not permitted
I: main.c: This is PulseAudio 0.9.10
I: main.c: Page size is 4096 bytes
I: main.c: Fresh high-resolution timers available! Bon appetit!
D: cli-command.c: Checking for existance of '/usr/lib/pulse-0.9/modules/module-hal-detect.so': success
I: module-hal-detect.c: Trying capability alsa
D: module-hal-detect.c: Not loaded device /org/freedesktop/Hal/devices/computer_alsa_timer
D: module-hal-detect.c: Not loaded device /org/freedesktop/Hal/devices/computer_alsa_sequencer
D: module-hal-detect.c: Not loaded device /org/freedesktop/Hal/devices/pci_8086_24d5_sound_card_0_alsa_playback_4
D: module-hal-detect.c: Not loaded device /org/freedesktop/Hal/devices/pci_8086_24d5_sound_card_0_alsa_capture_3
D: module-hal-detect.c: Not loaded device /org/freedesktop/Hal/devices/pci_8086_24d5_sound_card_0_alsa_capture_2
D: module-hal-detect.c: Not loaded device /org/freedesktop/Hal/devices/pci_8086_24d5_sound_card_0_alsa_capture_1
D: module-hal-detect.c: Loading module-alsa-sink with arguments 'device_id=0 sink_name=alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0'
D: alsa-util.c: Trying front:0...
I: module-alsa-sink.c: Successfully opened device front:0.
I: module-alsa-sink.c: Successfully enabled mmap() mode.
ALSA lib control.c:909Sadsnd_ctl_open_noupdate) Invalid CTL front:0
I: alsa-util.c: Unable to attach to mixer front:0: No such file or directory
I: alsa-util.c: Successfully attached to mixer 'hw:0'
I: alsa-util.c: Using mixer control "Master".
I: sink.c: Created sink 0 "alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0" with sample spec "s16le 2ch 44100Hz"
I: source.c: Created source 0 "alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0.monitor" with sample spec "s16le 2ch 44100Hz"
I: module-alsa-sink.c: Using 8 fragments of size 880 bytes.
I: alsa-util.c: All 2 channels can be mapped to mixer channels. Using hardware volume control.
D: module-alsa-sink.c: Thread starting up
D: rtpoll.c: Acquired POSIX realtime signal SIGRTMIN+29
I: module-alsa-sink.c: Starting playback.
I: module.c: Loaded "module-alsa-sink" (index: #0; argument: "device_id=0 sink_name=alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0").
D: module-hal-detect.c: Loading module-alsa-source with arguments 'device_id=0 source_name=alsa_input.pci_8086_24d5_sound_card_0_alsa_capture_0'
I: module-alsa-source.c: Successfully opened device front:0.
I: module-alsa-source.c: Successfully enabled mmap() mode.
I: alsa-util.c: Using mixer control "Capture".
I: source.c: Created source 1 "alsa_input.pci_8086_24d5_sound_card_0_alsa_capture_0" with sample spec "s16le 2ch 44100Hz"
I: module-alsa-source.c: Using 8 fragments of size 880 bytes.
D: module-alsa-source.c: Thread starting up
D: rtpoll.c: Acquired POSIX realtime signal SIGRTMIN+28
I: module.c: Loaded "module-alsa-source" (index: #1; argument: "device_id=0 source_name=alsa_input.pci_8086_24d5_sound_card_0_alsa_capture_0").
D: module-hal-detect.c: Not loaded device /org/freedesktop/Hal/devices/pci_8086_24d5_sound_card_0_alsa_control__1
D: module-hal-detect.c: Loading module-alsa-source with arguments 'device_id=1 source_name=alsa_input.usb_device_5a9_2643_noserial_if2_sound_card_0_alsa_capture_0'
D: alsa-util.c: Trying front:1...
I: alsa-util.c: PCM device front:1 refused our hw parameters: Invalid argument
...and the rest (previous post was too long and I split up the content (using Ubuntu Hardy 8.04 i686; and xbmc Atlantis PPA):
D: alsa-util.c: Trying surround40:1...
I: alsa-util.c: PCM device surround40:1 refused our hw parameters: Invalid argument
D: alsa-util.c: Trying surround41:1...
I: alsa-util.c: PCM device surround41:1 refused our hw parameters: Invalid argument
D: alsa-util.c: Trying surround50:1...
I: alsa-util.c: PCM device surround50:1 refused our hw parameters: Invalid argument
D: alsa-util.c: Trying surround51:1...
I: alsa-util.c: PCM device surround51:1 refused our hw parameters: Invalid argument
D: alsa-util.c: Trying surround71:1...
I: alsa-util.c: PCM device surround71:1 refused our hw parameters: Invalid argument
D: alsa-util.c: Trying hw:1 as last resort...
I: module-alsa-source.c: Successfully opened device hw:1.
W: alsa-util.c: Unable to determine current swparams: Operation not permitted
I: alsa-util.c: Successfully attached to mixer 'hw:1'
I: alsa-util.c: Cannot find mixer control "Capture".
I: alsa-util.c: Using mixer control "Mic".
I: source.c: Created source 2 "alsa_input.usb_device_5a9_2643_noserial_if2_sound_card_0_alsa_capture_0" with sample spec "s16le 2ch 44100Hz"
I: alsa-util.c: ALSA device lacks separate volumes control for channel 'front-right', falling back to software volume control.
D: rtpoll.c: Acquired POSIX realtime signal SIGRTMIN+27
W: module-alsa-source.c: Got POLLERR from ALSA
W: module-alsa-source.c: Could not recover from POLLERR|POLLNVAL|POLLHUP with snd_pcm_prepare(): Input/output error
I: module.c: Loaded "module-alsa-source" (index: #2; argument: "device_id=1 source_name=alsa_input.usb_device_5a9_2643_noserial_if2_sound_card_0_alsa_capture_0").
D: module-hal-detect.c: Not loaded device /org/freedesktop/Hal/devices/usb_device_5a9_2643_noserial_if2_sound_card_0_alsa_control__1
I: module-hal-detect.c: Loaded 3 modules.
I: module.c: Loaded "module-hal-detect" (index: #3; argument: "").
D: cli-command.c: Checking for existance of '/usr/lib/pulse-0.9/modules/module-esound-protocol-unix.so': success
I: module.c: Loaded "module-esound-protocol-unix" (index: #4; argument: "").
I: protocol-native.c: loading cookie from disk.
I: module.c: Loaded "module-native-protocol-unix" (index: #5; argument: "").
D: cli-command.c: Checking for existance of '/usr/lib/pulse-0.9/modules/module-gconf.so': success
I: module.c: Loaded "module-gconf" (index: #6; argument: "").
I: module.c: Loaded "module-volume-restore" (index: #7; argument: "").
D: module-default-device-restore.c: Restored default sink 'alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0'.
D: core-subscribe.c: dropped redundant event.
D: module-default-device-restore.c: Restored default source 'alsa_input.pci_8086_24d5_sound_card_0_alsa_capture_0'.
I: module.c: Loaded "module-default-device-restore" (index: #8; argument: "").
I: module.c: Loaded "module-rescue-streams" (index: #9; argument: "").
D: module-suspend-on-idle.c: Sink alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0 becomes idle.
D: module-suspend-on-idle.c: Source alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0.monitor becomes idle.
D: module-suspend-on-idle.c: Source alsa_input.pci_8086_24d5_sound_card_0_alsa_capture_0 becomes idle.
D: module-suspend-on-idle.c: Source alsa_input.usb_device_5a9_2643_noserial_if2_sound_card_0_alsa_capture_0 becomes idle.
I: module.c: Loaded "module-suspend-on-idle" (index: #10; argument: "").
D: cli-command.c: Checking for existance of '/usr/lib/pulse-0.9/modules/module-x11-publish.so': success
D: module-x11-publish.c: using already loaded auth cookie.
I: module.c: Loaded "module-x11-publish" (index: #11; argument: "").
I: main.c: Daemon startup complete.
D: module-hal-detect.c: dbus: interface=org.freedesktop.DBus, path=/org/freedesktop/DBus, member=NameAcquired
I: module.c: Unloading "module-alsa-source" (index: #2).
D: module-rescue-streams.c: No source outputs to move away.
D: module-alsa-source.c: Thread shutting down
I: source.c: Freeing source 2 "alsa_input.usb_device_5a9_2643_noserial_if2_sound_card_0_alsa_capture_0"
I: module.c: Unloaded "module-alsa-source" (index: #2).
I: module-suspend-on-idle.c: Source alsa_input.pci_8086_24d5_sound_card_0_alsa_capture_0 idle for too long, suspending ...
I: module-alsa-source.c: Device suspended...
I: module-suspend-on-idle.c: Source alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0.monitor idle for too long, suspending ...
I: module-suspend-on-idle.c: Sink alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0 idle for too long, suspending ...
I: module-alsa-sink.c: Device suspended...
I: client.c: Created 0 "Native client (UNIX socket client)"
I: protocol-native.c: Got credentials: uid=1000 gid=1000 success=1
I: protocol-native.c: Enabled SHM for new connection
I: client.c: Client 0 changed name from "Native client (UNIX socket client)" to "Test stream"
I: module-volume-restore.c: Restoring sink for <pulsecore/protocol-native.c$Test stream>
I: module-volume-restore.c: Restoring volume for <pulsecore/protocol-native.c$Test stream>
I: module-alsa-sink.c: Trying resume...
I: module-alsa-sink.c: Resumed successfully...
D: module-suspend-on-idle.c: Sink alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0 becomes busy.
D: resampler.c: Channel matrix:
D: resampler.c: I00
D: resampler.c: +------
D: resampler.c: O00 | 1.000
D: resampler.c: O01 | 1.000
I: resampler.c: Using resampler 'speex-float-1'
I: resampler.c: Using float32le as working format.
I: resampler.c: Choosing speex quality setting 1.
I: sink-input.c: Created input 0 "Simple DirectMedia Layer" on alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0 with sample spec u8 1ch 11025Hz and channel map mono
D: memblockq.c: memblockq requested: maxlength=8268, tlength=5512, base=1, prebuf=5402, minreq=110
D: memblockq.c: memblockq sanitized: maxlength=8268, tlength=5512, base=1, prebuf=5402, minreq=110
I: sink-input.c: Freeing output 0 "Simple DirectMedia Layer"
I: client.c: Freed 0 "Test stream"
I: protocol-native.c: connection died.
I: client.c: Created 1 "Native client (UNIX socket client)"
I: client.c: Client 1 changed name from "Native client (UNIX socket client)" to "xbmc.bin"
I: module-volume-restore.c: Restoring sink for <pulsecore/protocol-native.c$xbmc.bin>
I: module-volume-restore.c: Restoring volume for <pulsecore/protocol-native.c$xbmc.bin>
I: sink-input.c: Created input 1 "Simple DirectMedia Layer" on alsa_output.pci_8086_24d5_sound_card_0_alsa_playback_0 with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
D: memblockq.c: memblockq requested: maxlength=32768, tlength=32768, base=4, prebuf=32768, minreq=16384
D: memblockq.c: memblockq sanitized: maxlength=32768, tlength=32768, base=4, prebuf=32768, minreq=4
I: sink-input.c: Freeing output 1 "Simple DirectMedia Layer"
I: client.c: Freed 1 "xbmc.bin"
sparkiemark Wrote:Dude, do you not think I've been combing through search for months on this. Generally 'Search' utilities suck in forums. "Really fast video" doesn't return much of anything useful and "no sound" returns dozens of hits - most of which do not apply to my situation it seems. Unless one knows the solution (i.e. PulseAudio - thanks by the way), already, it can sometimes be difficult to find hits that can address the right problem.
Did you even read the link I posted above about how to post useful info about your problem? You need to provide the info specific to XBMC so the problem can be diagnosed from there.
