It is a little long, but here it is. Most of this I've found by trial and error, and I do not really know what I am doing or why it works, but it does. I should do more research, but haven't... Also I am more used to fedora linux (from the time it was called "red hat linux" and then "fedora core"), so some things perhaps should be done differently here. But it works for me.
First, become root entering "su -" and then the root password.
1) do "ls -l /dev/input/*" with the IR sensor not attached. Attach the sensor and repeat "ls -l /dev/input/*". That way you can see what devices the sensor creates.
2) then do "udevadm info -a -p $(udevadm info -q path -n /dev/input/eventX)" ("X" being the "event number" you discovered on step 1, mine was "5")
There will be a long listing; look for the FIRST "ATTRS(modalias)" line, for me it was:
ATTRS{modalias}=="input:b0003v06B4p1C70e0110-e0,1,2,3,4,14,k71,72,73,74,75,77,79,7A,7B,7C,7D,7E,7F,80,81,82,83,84,85,86,87,88,89,8A,8B,8C,8E,8F,90,96,98,9B,9C,9E,9F,A1,A3,A4,A5,A6,A7,A8,A9,AB,AC,AD,AE,B1,B2,B5,B7,B8,B9,BA,BB,BC,BD,BE,BF,C0,C1,C2,CE,CF,D0,D1,D2,D5,D9,DB,E2,EA,EB,F0,100,101,102,103,104,105,106,107,108,109,10A,10B,10C,10D,10E,10F,110,111,112,113,114,115,116,117,118,119,11A,11B,11C,11D,11E,11F,120,121,122,123,124,125,126,127,128,129,12A,12B,12C,12D,12E,12F,130,131,132,133,162,166,16A,16E,178,179,17A,17B,17C,17D,17F,180,181,182,185,18C,18D,192,193,195,1A0,1A1,1A2,1A3,1A4,1A5,1A6,1A7,1A8,1A9,1AA,1AB,1AC,1AD,1AE,1B0,1B1,1B7,r0,1,6,8,9,a10,11,20,m4,lsfw"
Of course, instead of "b0003v06B4p1C70e0110-e0*", enter the correct data for your device that you found on step 2
Now, by unplugging/plugging the USB IR sensor (or, if that does not work, rebooting) you should have a redirection for the device; "ls -l /dev/input/*" should give something like:
captures the input from the remote, you just need to execute that on each boot. I do that by creating a script on init.d:
With that, and the adecuate Lircmap.xml and Keymap.xml in the ~/.xbmc/userdata directory (or /usr/share/xbmc/userdata if you want it to work for every user) you can control xbmc with the remote as I explained before.
