Full Version: Xmbs crashes after very start
Hi All
I have installed xmbs on my ubuntu system and it is installed properly. But when I starts it it gives following error:
03:44:57 T:3068028768 M:2040422400 WARNING: CopyFile, cant open file </usr/share/xbmc/userdata/Lircmap.xml>. trying to use lowercase </usr/share/xbmc/userdata/lircmap.xml>
03:44:57 T:3068028768 M:2040422400 ERROR: CopyFile - cant open source file </usr/share/xbmc/userdata/Lircmap.xml>
03:44:57 T:3068028768 M:2040422400 NOTICE:
03:44:57 T:3068028768 M:2040246272 NOTICE: Setup SDL
03:44:57 T:3068028768 M:2039525376 INFO: Available videomodes (xrandr):
03:44:57 T:3068028768 M:2039525376 INFO: Number of connected outputs: 1
03:44:57 T:3068028768 M:2039525376 INFO: Output 'VGA' has 34 modes
03:44:57 T:3068028768 M:2039525376 INFO: ID:0x3d Name:1440x900 Refresh:59.887440 Width:1440 Height:900
03:44:57 T:3068028768 M:2039525376 INFO: Pixel Ratio: 1.049020
03:44:57 T:3068028768 M:2039525376 INFO: ID:0x43 Name:1440x900
03:44:57 T:3068028768 M:2039525376 INFO: Pixel Ratio: 1.258824
03:44:57 T:3068028768 M:2039525376 INFO: ID:0x5c Name:720x400 Refresh:70.081673 Width:720 Height:400
03:44:57 T:3068028768 M:2039525376 INFO: Pixel Ratio: 0.932462
03:44:57 T:3068028768 M:2039525376 INFO: LIRC Initialize: connect failed: No such file or directory
03:44:57 T:3068028768 M:2039525376 INFO: Drives are mapped
03:44:57 T:3068028768 M:2039525376 NOTICE: load settings...
03:44:57 T:3068028768 M:2039525376 NOTICE: Mapping drive P to /home/user1/.xbmc/userdata
03:44:57 T:3068028768 M:2039525376 NOTICE: loading /home/user1/.xbmc/userdata/guisettings.xml
03:44:57 T:3068028768 M:2039525376 NOTICE: Getting hardware information now...
03:44:57 T:3068028768 M:2039525376 INFO: Using analog output
03:44:57 T:3068028768 M:2039525376 INFO: AC3 pass through is enabled
03:44:57 T:3068028768 M:2039525376 INFO: DTS pass through is enabled
03:44:57 T:3068028768 M:2039525376 NOTICE: Checking resolution 10
03:44:57 T:3068028768 M:2039525376 NOTICE: Setting autoresolution mode 1
03:44:57 T:3068028768 M:2039525376 NOTICE: No advancedsettings.xml to load (/home/user1/.xbmc/userdata/advancedsettings.xml)
03:44:57 T:3068028768 M:2039525376 NOTICE: /home/user1/.xbmc/userdata/sources.xml
03:44:57 T:3068028768 M:2039525376 ERROR: Load Error loading /home/user1/.xbmc/userdata/sources.xml: Line 0, Failed to open file
03:44:57 T:3068028768 M:2039525376 INFO: Checking skinpath existence, and existence of keymap.xml:Q:\skin...
03:44:57 T:3068028768 M:2039525376 INFO: XRANDR: /usr/share/xbmc/xbmc-xrandr --output VGA --mode 0x3d
03:44:58 T:3068028768 M:2035601408 DEBUG: Constructing surface 1280x720, shared=(nil), fullscreen=0
03:44:58 T:3068028768 M:2035601408 INFO: GLX Info: NOT Using destination window
03:44:58 T:3068028768 M:2035601408 INFO: GLX Info: Using parent window
03:44:58 T:3068028768 M:2035613696 INFO: GLX Info: Creating unshared context
03:44:58 T:3068028768 M:2034167808 INFO: GL_VENDOR = Tungsten Graphics, Inc
03:44:58 T:3068028768 M:2034167808 INFO: GL_RENDERER = Mesa DRI Intel® 965G 20061102 x86/MMX/SSE2
03:44:58 T:3068028768 M:2034167808 INFO: GL_VERSION = 1.4 Mesa 7.2
03:44:58 T:3068028768 M:2034167808 INFO: GL_EXTENSIONS = GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_multisample GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_120 GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_cull_vertex GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_depth_st
03:44:58 T:3068028768 M:2034016256 INFO: GL: Maximum texture width: 2048
03:44:58 T:3068028768 M:2034016256 INFO: load language info file: /usr/share/xbmc/language/English/langinfo.xml
03:44:58 T:3068028768 M:2034016256 DEBUG: SECTION:LoadDLL(Q:\system\ImageLib-i486-linux.so)
03:44:58 T:3068028768 M:2034016256 DEBUG: Loading: /usr/share/xbmc/system/ImageLib-i486-linux.so
03:44:58 T:3068028768 M:2034016256 WARNING: CreateFile, successfuly opened </usr/share/xbmc/media/Splash.png> instead of </usr/share/xbmc/media/splash.png>
03:44:58 T:3068028768 M:2032197632 DEBUG: PICTURE: loaded image and created texture. height: 401, width: 721
03:44:58 T:3068028768 M:2031742976 DEBUG: Load /usr/share/xbmc/media/splash.png: 46.1ms
03:44:58 T:3068028768 M:2031742976 INFO: load language file:/usr/share/xbmc/language/English/strings.xml
03:44:58 T:3068028768 M:2031439872 INFO: load keymapping
03:44:58 T:3068028768 M:2031439872 INFO: Loading /usr/share/xbmc/system/Keymap.xml
03:44:58 T:3068028768 M:2031439872 DEBUG: CButtonTranslator::Load - no userdata keymap found, skipping
03:44:58 T:3068028768 M:2031439872 INFO: Loading /usr/share/xbmc/system/Lircmap.xml
03:44:58 T:3068028768 M:2031439872 INFO: Loading /home/user1/.xbmc/userdata/Lircmap.xml
03:44:58 T:3068028768 M:2031439872 INFO: Checking skin version of: PM3.HD
03:44:58 T:3068028768 M:2031439872 INFO: The above skin isn't suitable - checking the version of the default: PM3.HD
03:44:58 T:3068028768 M:2031439872 WARNING: Emergency recovery console starting...
Please help!!!
Thanks in advance.
Sac
