2009-02-22, 01:23
I'm trying catalyst 9.2 with my radeon x1600 and xbmc won't start...
Here is the log:
I'm using xbmc-svn 17392
Here is the log:
22:41:24 T:3071469408 M:189603840 NOTICE: Mapping drive Z to /tmp/xbmc-mediacenter
22:41:24 T:3071469408 M:189603840 NOTICE: Mapping drive Q to /usr/share/xbmc
22:41:24 T:3071469408 M:189603840 NOTICE: Mapping drive U to /home/mediacenter/.xbmc
22:41:24 T:3071469408 M:189603840 NOTICE: Mapping drive T to /home/mediacenter/.xbmc/userdata
22:41:24 T:3071469408 M:189603840 WARNING: CopyFile, cant open file </usr/share/xbmc/userdata/Lircmap.xml>. trying to use lowercase </usr/share/xbmc/userdata/lircmap.xml>
22:41:24 T:3071469408 M:189603840 ERROR: CopyFile - cant open source file </usr/share/xbmc/userdata/Lircmap.xml>
22:41:24 T:3071469408 M:189603840 NOTICE: -----------------------------------------------------------------------
22:41:24 T:3071469408 M:189603840 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Jan 27 2009 (SVN:17392)
22:41:24 T:3071469408 M:189603840 NOTICE: Q is mapped to: /usr/share/xbmc
22:41:24 T:3071469408 M:189603840 NOTICE: The executable running is: /usr/share/xbmc/xbmc.bin
22:41:24 T:3071469408 M:189603840 NOTICE: Log File is located: /var/tmp/mediacenter-xbmc.log
22:41:24 T:3071469408 M:188416000 NOTICE: Setup SDL
22:41:24 T:3071469408 M:187543552 NOTICE: load settings...
22:41:24 T:3071469408 M:187543552 NOTICE: Mapping drive P to /home/mediacenter/.xbmc/userdata
22:41:24 T:3071469408 M:187543552 NOTICE: loading /home/mediacenter/.xbmc/userdata/guisettings.xml
22:41:24 T:3071469408 M:187543552 NOTICE: Getting hardware information now...
22:41:24 T:3071469408 M:187543552 NOTICE: Checking resolution 12
22:41:24 T:3071469408 M:187543552 NOTICE: No advancedsettings.xml to load (/home/mediacenter/.xbmc/userdata/advancedsettings.xml)
22:41:24 T:3071469408 M:187543552 NOTICE: Default Video Player: dvdplayer
22:41:24 T:3071469408 M:187543552 NOTICE: Default Audio Player: paplayer
22:41:24 T:3071469408 M:187543552 NOTICE: /home/mediacenter/.xbmc/userdata/sources.xml
22:41:24 T:3071469408 M:187543552 WARNING: CXRandR::SetMode: found alternative mode (same hz): default mode: 0x49.
22:41:24 T:3071469408 M:186351616 ERROR: (pthread_mutex_destroy(&m_mutex)): [XCriticalSection.cpp:86] 16
