2009-02-25, 03:04
Using Jesters 18004 build. I was previously using the jester 17522 build and whenever I hit scan for new content it would quickly scan my media folder first for any .nfo and .tbn files I have already setup in place with xbmc media companion. I was having the occasional xbmc has failed to load error with this build and I would have to just restore the guisettings.xml file from a backup every once in a while so I decided to update to the latest jester build. now when I try to scan for new content on my media folders the scan is taking HOURS instead of minutes (well over 1000+ video files) this is usually an indication that its scraping anew from IMDB instead of using the .nfo's I already have. is there a way to force it to scan my local files for the .nfo's 1st using some tag in the advancedsettings.xml file or whatever? having all my .nfo's and .tbn's stored locally greatly speeds up the library update function after installing new builds!
quick recap to make sense of my rambling: worked fine in jesters 17522...doesnt work fine in 18004! thanks in advance!
