Full Version: DVD not mounted
Dear all,
im running xbmc on moblin which using kernel 2.6.29.rc5-28.1.moblin2-netbook. my window manager is XFCE. i have disabled the automount for removable media in my XFCE.
The problem that im facing now is when i inserted my DVD xbmc is not doing the mounting automatically so due to the automount is failed the play button is not appearing at the bottom of the main menu.
below is the log file that i capture
14:44:00 T:3067168608 M: 8441856 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_DRW_2014L1T) Property storage.removable.media_available modified
14:44:00 T:3067168608 M: 8441856 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_DRW_2014L1T) Property storage.cdrom.write_speeds modified
14:44:00 T:3067168608 M: 8441856 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_DRW_2014L1T) Property storage.cdrom.write_speed modified
14:44:00 T:3067168608 M: 8441856 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_DRW_2014L1T) Property storage.cdrom.read_speed modified
14:44:04 T:3067168608 M: 7995392 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/volume_label_POLAR_EXPRESS) Added
14:44:04 T:3067168608 M: 7995392 DEBUG: HAL: Added - cdrom | FileSystem udf | HotPlugged NO | Type 2 |Approved YES
14:44:04 T:3067168608 M: 7995392 NOTICE: LFS: Added - cdrom | POLAR_EXPRESS
14:44:56 T:316619664 M: 17477632 INFO: Not Following Redirect - Server returned: 302 Found
14:44:56 T:316619664 M: 17477632 DEBUG: staticThread, deleting thread object
14:44:56 T:316619664 M: 17477632 DEBUG: staticThread, deleting thread graphic context
14:44:56 T:316619664 M: 17477632 DEBUG: Thread 316619664 terminati
if i set to automount the dvd been detected as folder where i can view at filemanager n play the movie manualy by browse the file,,the Play button is still failed to appear and if i try browse my dvd drive the error showing no disc.
below is the log file for this scenario.i capture it from starting of my xbmc. the eject option also is not functioning. for ur information my xbmc already set for auton run when dvd or any cd been insert.
14:51:08 T:3067021152 M: 56721408 INFO: HAL: Sucessfully initialized
14:51:08 T:3067021152 M: 56721408 NOTICE: initialize done
14:51:08 T:3067021152 M: 56721408 NOTICE: Running the application...
14:51:08 T:3067021152 M: 56721408 INFO: initializing python engine.
14:51:08 T:3067021152 M: 56721408 DEBUG: Loading: /usr/local/share/xbmc/system/python/python24-i486-linux.so
14:51:09 T:3009186704 M: 56160256 INFO: Not Following Redirect - Server returned: 302 Found
14:51:09 T:3009186704 M: 56160256 DEBUG: staticThread, deleting thread object
14:51:09 T:3009186704 M: 56160256 DEBUG: staticThread, deleting thread graphic context
14:51:09 T:3009186704 M: 56160256 DEBUG: Thread 3009186704 terminating
14:51:09 T:3042741136 M: 56111104 INFO: WEATHER: Weather download successful
14:51:10 T:3042741136 M: 51040256 DEBUG: staticThread, deleting thread object
14:51:10 T:3042741136 M: 51040256 DEBUG: staticThread, deleting thread graphic context
14:51:10 T:3042741136 M: 51040256 DEBUG: Thread 3042741136 terminating
14:51:11 T:3067021152 M: 42872832 DEBUG: new python thread created. id=1
14:51:11 T:2918185872 M: 42872832 DEBUG: Running thread 2918185872
14:51:11 T:2918185872 M: 42872832 DEBUG: thread start, auto delete: 0
14:51:11 T:3067021152 M: 42872832 DEBUG: NetworkMessage - Starting network services
14:51:11 T:2918185872 M: 42872832 DEBUG: Python thread: start processing
14:51:11 T:3067021152 M: 42872832 NOTICE: ES: Starting event server
14:51:11 T:2909797264 M: 42872832 DEBUG: Running thread 2909797264
14:51:11 T:2909797264 M: 42872832 DEBUG: thread start, auto delete: 0
14:51:11 T:2901408656 M: 42872832 DEBUG: Running thread 2901408656
14:51:11 T:2909797264 M: 42872832 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
14:51:11 T:2909797264 M: 42872832 NOTICE: UDP: Listening on port 9777
14:51:11 T:3067021152 M: 40226816 DEBUG: Load background-videos.jpg: 57.8ms (bundled)
14:51:11 T:3067021152 M: 31744000 DEBUG: Load Background-Home-2.png: 109.0ms (bundled)
14:51:11 T:3067021152 M: 30576640 DEBUG: Load Home-Menu-Back.png: 15.2ms (bundled)
14:51:11 T:2918185872 M: 30576640 NOTICE: -->Python Interpreter Initialized<--
14:51:11 T:2918185872 M: 30576640 INFO: Scriptresult: Succes
14:51:11 T:3067021152 M: 31744000 DEBUG: Load home-button-focus.gif: 10.4ms (bundled)
14:51:11 T:3067021152 M: 30031872 DEBUG: Load Header.png: 21.7ms (bundled)
14:51:11 T:3067021152 M: 30031872 DEBUG: Load xbmc-logo.png: 4.5ms (bundled)
14:51:11 T:3067021152 M: 27385856 DEBUG: Load Footer.png: 20.5ms (bundled)
14:51:12 T:2868857744 M: 26169344 DEBUG: Running thread 2868857744
14:51:12 T:2868857744 M: 26169344 DEBUG: thread start, auto delete: 0
14:51:12 T:2868857744 M: 26169344 INFO: Get URL: http://feeds.feedburner.com/xbmc
14:51:12 T:2918185872 M: 26091520 DEBUG: xbp_dlopen loading python lib /usr/local/share/xbmc/system/python/python24.zip/time.so. flags: 2
14:51:12 T:2918185872 M: 26091520 DEBUG: Loading: /tmp/xbmc-emagine/time.so
14:51:12 T:2918185872 M: 26091520 DEBUG: RegisterExtensionLib, adding Z:/time.so (0xb63202b8)
14:51:12 T:2918185872 M: 26091520 DEBUG: xbp_dlsym - load symbol inittime
14:51:12 T:2918185872 M: 26005504 DEBUG: xbp_dlopen loading python lib /usr/local/share/xbmc/system/python/python24.zip/collections.so. flags: 2
14:51:12 T:2918185872 M: 25538560 DEBUG: Loading: /tmp/xbmc-emagine/collections.so
14:51:12 T:2918185872 M: 25538560 DEBUG: RegisterExtensionLib, adding Z:/collections.so (0xb638e618)
14:51:12 T:2918185872 M: 25538560 DEBUG: xbp_dlsym - load symbol initcollections
14:51:12 T:2918185872 M: 25538560 INFO: Python script stopped
14:51:12 T:2918185872 M: 25538560 DEBUG: staticThread, deleting thread graphic context
14:51:12 T:2918185872 M: 25538560 DEBUG: Thread 2918185872 terminating
14:51:12 T:3067021152 M: 25538560 DEBUG: python thread 1 destructed
14:51:12 T:3067021152 M: 25538560 INFO: Python, unloading python24.dll because no scripts are running anymore
14:51:12 T:3067021152 M: 25538560 DEBUG: UnloadExtensionLibs, clearing python extension libraries
14:51:12 T:3067021152 M: 25538560 DEBUG: Unloading: Z:/time.so
14:51:12 T:3067021152 M: 25538560 DEBUG: Unloading: Z:/collections.so
14:51:12 T:3067021152 M: 25538560 DEBUG: Unloading: python24-i486-linux.so
14:51:13 T:2868857744 M: 25571328 DEBUG: Got rss feed: http://feeds.feedburner.com/xbmc
14:51:13 T:2868857744 M: 25571328 DEBUG: RSS feed encoding: UTF-8
14:51:13 T:2868857744 M: 25571328 DEBUG: Parsed rss feed: http://feeds.feedburner.com/xbmc
14:51:13 T:2868857744 M: 25571328 DEBUG: staticThread, deleting thread graphic context
14:51:13 T:2868857744 M: 25571328 DEBUG: Thread 2868857744 terminating
14:51:37 T:3067021152 M: 25882624 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\ImageLib-i486-linux.so)
14:51:37 T:3067021152 M: 25882624 DEBUG: Unloading: ImageLib-i486-linux.so
14:53:08 T:3067021152 M: 25083904 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_DRW_2014L1T) Property storage.removable.media_available modified
14:53:08 T:3067021152 M: 25083904 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_DRW_2014L1T) Property storage.cdrom.write_speeds modified
14:53:08 T:3067021152 M: 25083904 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_DRW_2014L1T) Property storage.cdrom.write_speed modified
14:53:08 T:3067021152 M: 25083904 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_DRW_2014L1T) Property storage.cdrom.read_speed modified
14:53:12 T:3067021152 M: 19779584 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/volume_label_POLAR_EXPRESS) Added
14:53:12 T:3067021152 M: 19546112 DEBUG: HAL: Added - cdrom | FileSystem udf | HotPlugged NO | Type 2 |Approved YES
14:53:12 T:3067021152 M: 19546112 NOTICE: LFS: Added - cdrom | POLAR_EXPRESS
14:53:14 T:3067021152 M: 20672512 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/volume_label_POLAR_EXPRESS) Property volume.mount_point modified
14:53:14 T:3067021152 M: 20594688 DEBUG: HAL: Update - cdrom | FileSystem udf | Mounted on /media/POLAR_EXPRESS | HotPlugged NO | Type 2 |Approved YES
14:53:14 T:3067021152 M: 20594688 NOTICE: LFS: Updated - cdrom | POLAR_EXPRESS
14:53:14 T:3067021152 M: 20594688 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/volume_label_POLAR_EXPRESS) Property volume.is_mounted_read_only modified
14:53:14 T:3067021152 M: 20594688 DEBUG: HAL: Device (/org/freedesktop/Hal/devices/volume_label_POLAR_EXPRESS) Property volume.is_mounted modified
14:54:31 T:3067021152 M: 5787648 DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
14:54:31 T:3067021152 M: 5787648 DEBUG: OnKey: 61453 pressed, action is 7
14:54:31 T:3067021152 M: 5787648 DEBUG: OnMessage : Translating XBMC.EjectTray()
14:54:31 T:3067021152 M: 5787648 DEBUG: OnMessage : To XBMC.EjectTray()
14:54:31 T:3067021152 M: 5632000 DEBUG: ------------------- GUI_MSG_WINDOW_DEINIT
Thanks,
Regards,
R.Shankar
xbmc --standalone
Will make XBMC handle the mounting, but the DVD mounting is far from good.
Also we canĀ“t handle unmounts, well rather the underlying code have zero problems unmounting, but jacking it into the guilib have been troublesome Smile
Cheers,
Tobias
im trying to figure out the same thing i think. i'm running XBMC without a window manager and now without thunar-volman none of the dvd discs are seen.
01:32:42 T:3048119184 M:2682781696   DEBUG: Drive closed media present, remounting...
01:32:42 T:3048119184 M:2682781696    INFO: Detecting DVD-ROM media filesystem...
01:32:42 T:3048119184 M:2682679296    INFO: CD Analysis Report
01:32:42 T:3048119184 M:2682679296    INFO: __________________________________
01:32:43 T:3048470352 M:2682679296   DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_CDDVDW_SH_S202J) Property storage.removable.media_available modified
01:32:43 T:3048470352 M:2682679296   DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_CDDVDW_SH_S202J) Property storage.removable.media_size modified
01:32:43 T:3048470352 M:2682679296   DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_CDDVDW_SH_S202J) Property storage.cdrom.write_speeds modified
01:32:43 T:3048470352 M:2682679296   DEBUG: HAL: Device (/org/freedesktop/Hal/devices/storage_model_CDDVDW_SH_S202J) Property storage.cdrom.write_speed modified
01:32:43 T:3048470352 M:2682679296   DEBUG: HAL: Device (/org/freedesktop/Hal/devices/volume_part_1_size_1073741312) Added
01:32:43 T:3048470352 M:2682679296   DEBUG: HAL: Added - cdrom | HotPlugged NO  | Type 2 |Approved NO
01:32:43 T:3048470352 M:2682679296  NOTICE: LFS: Added - cdrom | Volume
01:32:43 T:3048119184 M:2682679296    INFO: CD-ROM with UDF filesystem
01:32:43 T:3048119184 M:2682679296    INFO: UDF: version 1.02
01:32:43 T:3048119184 M:2682679296    INFO: Tracks overall:1; Audio tracks:0; Data tracks:1
01:32:43 T:3048119184 M:2682679296    INFO: Using protocol D:\
01:32:43 T:3048119184 M:2682679296    INFO: Disc label:
01:32:43 T:3048119184 M:2682679296   DEBUG: SetNewDVDShareUrl: looking for disc thumb:[D:\folder.jpg]
01:32:43 T:3048119184 M:2682679296   DEBUG: SetNewDVDShareUrl: looking for disc thumb:[D:\Folder.jpg]
01:32:43 T:3048119184 M:2682679296   DEBUG: SetNewDVDShareUrl: looking for disc thumb:[D:\folder.JPG]
01:32:43 T:3048119184 M:2682679296   DEBUG: SetNewDVDShareUrl: looking for disc thumb:[D:\Folder.JPG]
and that's it. the disc doesnt get mounted anywhere nor is it visible anywhere. is that normal behavior? same thing for running plain xbmc and running with --standalone.
I believe that if XBMC is running without a Window Manager to handle mounting then XBMC is going to be rather limited in it's ability to work with the mounts.
I don't know that for sure, but I would imagine that it might take a lot of work to write the code to handle that 100%.
Is there a daemon that could handle mounting outside of an X Window Manager? I've never seen that done before.
actually i might have been jumping the gun. an udf dvd did mount after some tries, apparently when i switched out of library mode. but regular dvd movies did not starting playing and i will switch dvdrom drives tomorrow to eliminate faulty drive case. will post updates.
