The follow up, that did not fit in the last post.
18:40:05 T:3068196656 M:1517441024 DEBUG: Open - av_find_stream_info finished
18:40:05 T:3068196656 M:1517441024 INFO: ffmpeg: Input #0, aac, from 'cdda://local/01.cdda':
18:40:05 T:3068196656 M:1517441024 INFO: ffmpeg: Duration: 24:52:16.44, bitrate: 5 kb/s
18:40:05 T:3068196656 M:1517441024 INFO: ffmpeg: Stream #0.0: Audio: aac, 88200 Hz, quad, s16, 5 kb/s
18:40:05 T:3068196656 M:1517441024 DEBUG: FactoryCodec - Audio: passthrough - Opening
18:40:05 T:3068196656 M:1517441024 DEBUG: FactoryCodec - Audio: passthrough - Failed
18:40:05 T:3068196656 M:1517441024 DEBUG: FactoryCodec - Audio: libfaad - Opening
18:40:05 T:3068196656 M:1517441024 DEBUG: SECTION:LoadDLL(special://xbmc/system/players/dvdplayer/libfaad-i486-linux.so)
18:40:05 T:3068196656 M:1517441024 DEBUG: Loading: /usr/share/xbmc/system/players/dvdplayer/libfaad-i486-linux.so
18:40:05 T:3068196656 M:1517441024 DEBUG: FactoryCodec - Audio: libfaad - Opened
18:40:05 T:3068196656 M:1517441024 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 3
18:40:05 T:3068196656 M:1517441024 ERROR: CDVDAudioCodecLibFaad() : Invalid number of channels
18:40:05 T:3068196656 M:1517346816 DEBUG: Open - av_find_stream_info starting
18:40:05 T:3068196656 M:1517346816 DEBUG: Open - av_find_stream_info finished
18:40:05 T:3068196656 M:1517346816 INFO: ffmpeg: Input #0, aac, from 'cdda://local/01.cdda':
18:40:05 T:3068196656 M:1517346816 INFO: ffmpeg: Duration: 24:52:16.44, bitrate: 5 kb/s
18:40:05 T:3068196656 M:1517346816 INFO: ffmpeg: Stream #0.0: Audio: aac, 88200 Hz, quad, s16, 5 kb/s
18:40:05 T:3068196656 M:1517346816 DEBUG: FactoryCodec - Audio: passthrough - Opening
18:40:05 T:3068196656 M:1517346816 DEBUG: FactoryCodec - Audio: passthrough - Failed
18:40:05 T:3068196656 M:1517346816 DEBUG: FactoryCodec - Audio: libfaad - Opening
18:40:05 T:3068196656 M:1517346816 DEBUG: FactoryCodec - Audio: libfaad - Opened
18:40:05 T:3068196656 M:1517346816 INFO: PAPlayer: Playing cdda://local/01.cdda
18:40:05 T:3068196656 M:1517346816 DEBUG: CALSADirectSound::CALSADirectSound - Channels: 4 - SampleRate: 44100 - SampleBit: 16 - Resample false - Codec - IsMusic true - IsPassthrough false - audioDevice: default
18:40:05 T:3068196656 M:1517346816 DEBUG: Initialize - using alsa device default
18:40:05 T:3068196656 M:1517346816 DEBUG: CALSADirectSound::Initialize - packet size:7520, packet count:8, buffer size:7526
18:40:05 T:3013475216 M:1517346816 DEBUG: Running thread 3013475216
18:40:05 T:3013475216 M:1517346816 DEBUG: thread start, auto delete: 0
18:40:05 T:3013475216 M:1517346816 DEBUG: PAPlayer: Thread started
18:40:05 T:3013475216 M:1517346816 DEBUG: Playback has started
18:40:05 T:3068196656 M:1517346816 DEBUG: SECTION:LoadDLL(special://xbmc/visualisations/opengl_spectrum.vis)
18:40:05 T:3068196656 M:1517346816 DEBUG: Loading: /usr/share/xbmc/visualisations/opengl_spectrum.vis
18:40:05 T:3013475216 M:1517207552 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 3
18:40:05 T:3013475216 M:1517207552 ERROR: CDVDAudioCodecLibFaad() : Invalid number of channels
18:40:05 T:3068196656 M:1517207552 DEBUG: create:520x347 at 200x67 opengl_spectrum
18:40:05 T:3068196656 M:1517207552 DEBUG: OnInitialize() started
18:40:05 T:3068196656 M:1517207552 DEBUG: Visualisation::Start()
18:40:05 T:3068196656 M:1517207552 DEBUG: Updating visualisation albumart: defaultAlbumCover.png
18:40:05 T:3068196656 M:1517207552 DEBUG: OnInitialize() done
18:40:05 T:3068196656 M:1516650496 DEBUG: Load defaultAlbumCover.png: 4.9ms (bundled)
18:40:05 T:3013475216 M:1516650496 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 4
18:40:05 T:3013475216 M:1516650496 ERROR: CDVDAudioCodecLibFaad() : Bitstream value not allowed by specification
18:40:05 T:3013475216 M:1516650496 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 6
18:40:05 T:3013475216 M:1516650496 ERROR: CDVDAudioCodecLibFaad() : Invalid number of channels
18:40:05 T:3013475216 M:1516650496 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 2
18:40:05 T:3068196656 M:1516650496 DEBUG: Load pointer-focus-click.png: 0.1ms (bundled)
18:40:05 T:3068196656 M:1516650496 DEBUG: CGUIInfoManager::SetCurrentSong(cdda://local/01.cdda)
18:40:05 T:3068196656 M:1516650496 NOTICE: Attempting to update the database MyMusic7.db from version 10 to 12
18:40:05 T:3068196656 M:1516650496 ERROR: SQLite: SQL error or missing database
Query: CREATE TABLE karaokedata ( iKaraNumber integer, idSong integer, iKaraDelay integer, strKaraEncoding text, strKaralyrics text, strKaraLyrFileCRC text )
18:40:05 T:3013475216 M:1516580864 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 2
18:40:05 T:3013475216 M:1516580864 ERROR: CDVDAudioCodecLibFaad() : Invalid number of channels
18:40:05 T:3068196656 M:1516302336 ERROR: Error attempting to update the database version!
18:40:05 T:3068196656 M:1516302336 ERROR: Can't update the database MyMusic7.db from version 10 to 12
18:40:05 T:3068196656 M:1516302336 DEBUG: LoadMusicTag: loading tag information for file: cdda://local/01.cdda
18:40:05 T:3068196656 M:1516302336 DEBUG: cddb local cache hit.
18:40:05 T:3068196656 M:1516302336 DEBUG: Xcddb::queryCDinfo discid [11125c12] already cached
18:40:05 T:3013475216 M:1516302336 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 6
18:40:05 T:3013475216 M:1516302336 ERROR: CDVDAudioCodecLibFaad() : Invalid number of channels
18:40:05 T:3068196656 M:1516302336 DEBUG: Loading additional tag info for file cdda://local/01.cdda
18:40:05 T:3068196656 M:1516302336 DEBUG: Updating visualisation albumart: defaultAlbumCover.png
18:40:05 T:3013475216 M:1516302336 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 1
18:40:05 T:3013475216 M:1516302336 ERROR: CDVDAudioCodecLibFaad() : Bitstream value not allowed by specification
18:40:05 T:3013475216 M:1516023808 ERROR: CDVDAudioCodecLibFaad() : Invalid number of channels
18:40:05 T:3013475216 M:1516023808 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 6
18:40:05 T:3013475216 M:1516023808 INFO: CDVDAudioCodecLibFaad::SyncStream(), stream synced at offset 8
18:40:05 T:3068196656 M:1516023808 DEBUG: Load home-playmedia.png: 0.7ms (bundled)
18:40:05 T:3068196656 M:1516023808 DEBUG: Load pointer-nofocus.png: 0.1ms (bundled)
