Full Version: Music Visualizations crash XBMC on my iMac
Hi all Smile Tried searching the forums for answers, but didn't see anything, so: Whenever I try to kick XBMC into Visualization mode, using PAPlayer or DVDPlayer, XBMC just crashes. Doesn't matter ProjectM, etc. I'm on an iMac with a Radeon HD2600 running 10.4.11.
My logs can be found here:
http://pastebin.com/m61c09fe5 xbmc.crash.log
http://pastebin.com/m3b15a24b console.log
I'm using an SVN build (rev17911) though it did this on Atlantis and every previous build I've tried.
It seems to be related to the following errors, which pop up in the log before it crashes:
Link (dyld) error:
Symbol not found: __ZN5CUtil13TranslatePathERK7CStdStrIcE
  Referenced from: /Users/Jinju/Library/Application Support/XBMC/visualisations/ProjectM.vis
  Expected in: flat namespace
Would love to get this working... I've been using XBMC for ages and am only now migrating away from the xbox. Thanks in advance for any help Smile
I'll look into this when I get a chance tonight.
I think CUtil::TranslatePath was removed sometime around rev17911. Can you svn up and see if the issue still persists? Although it's odd that you had the issue since Atlantis.
a quick look shows the xbmc binary and ProjectM.vis using the symbol
__ZN16CSpecialProtocol13TranslatePathERK7CStdStrIcE
instead of
using
nm build/Debug/XBMC | grep TranslatePath
nm visualisations/projectM/
I think your external libs/codecs build is stale. When building from svn always;
make clean
autoconf
./configure
make externals more_libs
then build from Xcode.
and if im using windows and am kinda clueless what to do?
started to crash after installing newest svn
neverthatgood Wrote:and if im using windows and am kinda clueless what to do?
If you are using windows (XBMC for Windows), then a better place to ask would be here http://forum.xbmc.org/forumdisplay.php?fid=59
