2009-02-27, 00:55
amd be-2400 + 780g driver (ati fglrx 8.561 or 8.58.2 ) + hardy 8.04 + xbmc (17908)
I followed the minimal installation guide, but after installation finished, I got two problems so far.
Problem 1) coredump occurs every time when I run "xbmc", but lateron I found eithe of the following solved the problem.
a) sudo xbmc or
b) LIBGL_ALWAYS_INDIRECT=true xbmc
Problem 2) It seems I cannot save any gui setting, from xbmc.log, I found
"Unable to save settings to special://masterprofile/guisettings.xml". I guess some xml libraryies are missing?
any ideas on these? thanks,
a) sudo xbmc or
