Full Version: help with svn repo
hi,
i installed xbmc from main page than installed kricker builds rev 18115 on it. now i dont know what i need to do or it is a problem. when i go on favorites and click on svn repo it show me empty folder. why?? what i need to do if i want install plugins(you tube,hulu...)
thx on answers
ok i solve the problem, i change svn repo with new which i downloaded from http://forum.xbmc.org/showthread.php?tid=29911
sorry if you think that it is a spam,
mod can delete this or lock
My problem is I know I when I go to scripts or favorites, they're both blank. Even though I have the svn repo in my plugins folder. Any ideas?
Nevermind, I had to move favourites.xml from my userdata folder to my system folder. Works fine now.
you boys having fun?
Please use the proper thread http://forum.xbmc.org/showthread.php?tid=29911 for problems with the SVN installer.
