2009-02-27, 17:16
Time has come for a new XBMC Live release: XBMC Live 8.10.2b1
Before going on, check the Wiki FAQ on XBMC Live.
This BETA release has to be considered as a total fresh start, since not only it is based on Ubuntu Intrepid (8.10.2), but also because I used a fresh, updated installation of the build tool.
It also marks the start to a new approach: I have created some pages in the XBMC Wiki where both the build process and the configuration process are briefly described, and I am looking forward to users' contributions in these pages so that both the quality and the completeness of the documents could increase. Not to mention omissisions and mistakes that this new beta release will carry in.
I need to stress the fact that this release was not tested in all details, and issues may arise here and there. However, identifying issues is the main cause I'm releasing it in the public: with help of all of you we may end up with something that barely works (sarcasm here...).
I need to anticipate that NVIDIA and ATI/AMD users may have to struggle to have a working setup, as in the previous releases, but that's a limitation of the restricted drivers not being tolerant interms of configuration files. Les't s hope that the newer releases will allow an higher number of success stories.
Details about the release:
* NVIDIA drivers: 180.29
* ATI/AMD drivers: Catalyst 9.1
* Intel drivers: default xorg
* Natively supports MCEUSB remotes
* New installer script that allows building of XBMCLive USB bootable disks from any Ubuntu-based system without the need of burning a CD and booting from it.
Finally, the SVN repositories sources are already configured, so updating XBMC to follow the bleeding edge will hopefully be easy - check your disk space!
NEW: when building XBMC Live with the installer from an existing Ubuntu PC be sure to disable the usb automount that may interfere with the installers actions:
gconftool-2 --set /apps/nautilus/preferences/media_automount --type=bool false
and later you can enable it again with:
gconftool-2 --set /apps/nautilus/preferences/media_automount --type=bool true
Wiki references:
Building the ISO image -
Configuring XBMC Live -
Building restricted drivers for XBMC Live
A quick TOC of what has been already asked:
Login to underlining OS: here
XBMC Live with ATI/AMD graphics controller boots to black screen?: here
Is Microsoft's MCE Remote the only remote that works in XBMC Live?: here
Live (HDD install) - Resume from Standby: here
AutoBoot settings for XBMC Live USB?: here - note that this release uses GRUB so info here are not 100% accurate
Backup XBMC Live USB in windows: here
FTP access to Live: here
XBMC live volume output too low: here
Wiki references:
