Full Version: <textcolor> and $INFO[] not working
<textcolor>$INFO[Window.Property(AlertsColor)]</textcolor>
no longer works
The property is properly set to "FFFF8040" orange.
i can manually set it to that so i know it's this tag that's not working.
TWC Supplemental is a test script, NY, NY currently has an alert if you need to test. the alert(s) tab is colored by the above tag.
Should be fixed in r18171.
Cheers,
Jonathan
yes, thanks
